1991 camaro z28 wont start
Old Aug 27, 2012 | 11:13 AM
JulesZ28's Avatar
Unhappy 1991 camaro z28 wont start
My dads camaro which he bought a few months ago. He had a mechanic look at it but couldnt find anything, he ran computer tests. the car has a hard idle and the rpm and oil gauges jump up and down. recently it started to not go over 20 mph and will stall at stop lights and stop signs. now the camaro will not start.
Old Aug 27, 2012 | 11:23 AM
JulesZ28's Avatar
Re: 1991 camaro z28 wont start
[autostream]http://autostream.com/camaroz28/?page_type=firebirdplayerthumbnail&framepage=2703& transactionid=1346084592-72177443&posted_by=JulesZ28_www.camaroz28.com&yout ube_video_id=uHvD0k2Vz7A[/autostream]
Old Aug 27, 2012 | 04:48 PM
96m6lt1's Avatar
Have you checked the fuel pressure? It should be 43psi minimum
Old Aug 27, 2012 | 05:27 PM
parkers Z28's Avatar
I hope that Im wrong but to me it sounds like the engine turns over to fast ??
could be the timing chain broke has it always turned over so fast?
and the guy checked to see if the plug was getting fire? and that you're getting fuel ??
Old Aug 27, 2012 | 07:44 PM
JulesZ28's Avatar
Fuel filter was changed, fuel pressure was perfect. It'll turn on after it cools, then when hot it idles rough and while driving. We tried heet to clean fuel injectors and worked for a day then back to busted. Today it was doing ok the it wouldn't shift out of 1st.(automatic)
Old Aug 29, 2012 | 04:26 AM
96m6lt1's Avatar
Have you checked the ICM?
'87-'92 distributors do take a dump after a while. So I would definitely pull it out and check it for excessive play in the shaft. A remand unit is about 100.00 its just another part to check....
Old Aug 30, 2012 | 04:27 PM
JulesZ28's Avatar
thanks ill check it out
CamaroHeed
Mar 18, 2020 09:50 PM
fpete1992
Dec 11, 2014 03:51 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
grendal
Apr 15, 2010 05:20 PM
2000silverz28
Jul 20, 2002 06:14 AM
