1.6 Rockers on 355 TPI?
Old Feb 26, 2003 | 03:00 PM
Mr. T's Z's Avatar
Can you or can't you run 1.6 rockers on the motor?
Tyler
Old Feb 26, 2003 | 03:54 PM
Bristol's Avatar
Im running them right now(Crane Gold race 1.6:1) but I have aftermarket heads and the machine shop whoinspected the heads took the specs of the cam and played with the springs. On a stock head I think you can. Not too sure though
Old Feb 26, 2003 | 07:11 PM
TheGreatJ's Avatar
You can with the appropriate valve springs. This may involve machine work on the spring seats which means you have to take your heads to a shop. If your cam isn't too wild you can probably find some stock diameter springs that will have enough lift capacity in which case you can just bolt the stuff on. It all depends on your heads and cam.
13qtr
Oct 28, 2016 08:11 PM
Quickss96
Jan 29, 2016 05:56 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
JCSWS6
Jul 19, 2015 06:47 PM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
