1/4 times
Old Jun 24, 2002 | 06:02 PM
  #16
3rdgen327's Avatar
Post
13.702 @ 106.18 in 2nd gear
stock 3.23 gears 25" tires and a 3000 stall th400
85,z-28,t-tops sbc 333CID 5.5 liter
harwood 6inch z-28 outlaw cowl pin on hood
MSD 6AL and MSD pro-billit distributor
soon holley 800cfm.carb. eld. victor jr. intake 1" taller,port matched, 1" spacer,
cast iron dobble hump heads 2.02 1.60 valves
53cc ported&polished
hooker headers 1 3/4 prim. 3inch collector full length
solid roller lifters 8620 billet cam @050 246 253 .585 .600
proform gear drive timing
forged egale SIR rods
trw forged flat tops
th400 tranny 3000 rpm stall
spohn proformance th400 crossmember and torque arm
spohn drive shaft
waiting to install spohn sub-frames
true dual 3 inch with 40 series flomasters exiting in front of rear tires
stock rear for now 3:23 gears 13.702 @ 106.18 in 2nd gear
Old Jun 24, 2002 | 11:19 PM
  #17
Yellowknifer's Avatar
Post
This is my understanding.
Firebird - 3500lbs
GT - 3600lbs
LX - 3300lbs
Camaro - 3400lbs
Old Jun 29, 2002 | 04:57 PM
  #18
3rdgen327's Avatar
Post
ttttt
Old Jun 29, 2002 | 09:37 PM
  #19
GMTech's Avatar
Post
It depends on what you have and what you have done. Unlike the V8 mustang, the V8 f-bodies had several engine combinations. You could have a 305 4bbl, 305 4bbl HO, 305 CFI, 305 TBI, 305 TPI, 350 TPI, etc... So the general rule is that if a person sees the slowest of them out there running, then they automaticly assume they are all slow. A 305 4bbl (LG4) and the 350 TPI (L98) are apples to oranges.
Also depends on what has been done. There are a plethera of parts out there for these cars, and a whole lot more NOT for these cars, which usually get installed anyway. Mismatched parts can really kill power. For example, my car, the ZZ4 cam I used really isn't for TPI applications, but I used it anyway. I could have been faster w/o effecting drivability w/ a better choice in cam. I also don't have a very adequate stall for my car either. I also have too much gear. TPIs don't generally like 3.73s (IMHO) Once again, poor planning. I could be much faster if I had just thought ahead...
I've seen modded 305's run 13's and modded 350's run 15's, so alot of it has to do w/ how you "modded" it.
Webmaster:SETHIRDGEN
GM Tech
ASE Master Auto Technician + L1
1987 Trans Am: 357ci
Ported TFS heads, ZZ4 cam, headers & exhuast and other go fast goodies
13.53 @ 103.77
Old Jun 30, 2002 | 10:48 PM
  #20
black84 z28's Avatar
Post
l-69 cars have alot of potential
Old Jun 30, 2002 | 11:11 PM
  #21
irocbob89's Avatar
Post
Hopping for mid to low 11's in the first car in the sig and HIGH 13s or low 14s in the second car in the sig. Give me about a year and the lt-1 i hope will be running in the mid 12's that is all i want out of that car.
3rd gens are GREAT cars to make fast, they all have great potetial. They are expensive though. Its nice when you dont get much respect out of these cars and you can blow the doors off of almost every car that pulls up next to you (first car in the sig )
But it also sucks hard when your just hanging out in a parking lot and your shoved off because you have a 3rd gen. I HATE THAT. anyways thats my .02
89' red iroc-z
386 stroker
Mini ram, 58mm tb
30#lbs,255 high flow fuel pump
slp cam, 1.6rr
edelbrock performer heads p+p 2.02 1.60
Hooker super comps, Mufflex 4' exhaust
Ford 9' 4.11 gears, detroit locker, 31 spline
Full suspension
B&M mega shifter,2800 stall
baer rear brakes,line lock
converted to speed density
Ed Wright dyno tuned
89'red Iroc-z 5.7 TPI
t-tops grey interior
free mods, exhaust
Lt-1 convertion in the works
Old Jun 30, 2002 | 11:24 PM
  #22
irocbob89's Avatar
Post
BTW: my experiance with racing mustangs is very broad (spell ?) anyways when i first got my iroc 4 years ago it was stock (350 tpi,K&N, flowmaster) for one year. I did ALOT of racing in that year to. I had about 5-6 friends with 5.0s from 88-93 they had exhaust and free mods done to theres. I NEVER once lost to them i would always have a fender or something on them. We went to the track many time also i always ran between a 9.5-9.8 (1/8 mile) at 73mph mostly. That was a pritty good running car for having 100k on it. 2 of the guys that drove the mustangs are great drivers and always had a great race against them but never lost.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
dawg irocz
Feb 10, 2015 10:33 AM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
