****in Dammit
ughhh Im right on the verge of firing up the new 355 and of coarse since i have underdrive pullies, the stock belt won't fit...wtf my friends 5.0 was able to use the stock belt...why cant camaros?
does anybody know belt i need? is there a part number i can take to autozone and get that belt?
Re: ****in Dammit
What company makes your underdrive pulleys? It should say what part number belt you need in the instructions.
Anyway, the stock belt for a 92 350 TPI is part number 945K6, which means it is 94.5 inches long and has 6 ribs. If you can, use the old belt for a reference or use a piece of string to estimate how long the belt needs to be, add or subtract that from the stock size belt, and then go to an auto parts store and ask for that belt. For example, if the belt needs to be 2" shorter, ask for a part number 925K6 belt.
Re: ****in Dammit
well they pullies were on the car when i got it so i dont know who makes em. But a guy on thirdgen.org says he has march 1's and that he uses the belt 930k6...so im going to try that...that sounds about right...about an inch and 1/2 off...
