2016+ Camaro News, Sightings, Pictures, and General Discussion All 2016+ 6th Gen Camaro news, photos, videos, and General Dsicussion
Camaro V6 lgx Stabikitrak and blink checkengine, Misfire detected - p0300
Old Apr 2, 2023 | 07:36 AM
henoh's Avatar
Camaro V6 lgx service Stabilitrak and blink checkengine, Misfire detected - p0300
hi,
i have a problem i can't solve. The car speaks. stabilitrack and checkengine. ENGINE has reduced power.
What did I check?, coils, spark plugs, air filter, I replaced one injection and the coil.
The spark plugs look fine except for the one in bank 2 which is black and looks like it is flooded or not burning the fuel mixture. I swapped coils from other banks, same thing. i swapped spark plugs from other banks same thing and every time the plug taken out of bank 2 is black. I disconnected all the coils one by one while the engine was running to check the response of the engine. when each coil is disconnected, the motor responds, which means the bank is working. this is different when bank 2 is disconnected. The motor does not respond to disconnection. works the same as before disconnection.
The car starts normally or almost normally. Every now and then it freezes and I have to press the button again. engine revs are not fluctuating. The check engine light came on once every 200 miles. the power was the same. currently engine power is limited. it doesn't turn over and it doesn't burn on bank 2. what's up with the exhaust and the engine. the engine shakes slightly. normal engine rpm speed.
Left side bank 2 right side bank 4
list of error....
Movies
Old injectors bank 2
I have been driving the car for 3 years. It has 48,000 miles on it now
Old Apr 2, 2023 | 09:13 AM
Re: Camaro V6 lgx Stabikitrak and blink checkengine, Misfire detected - p0300
To be very honest, there aren't any active 5th or 6th Gen owners on this site that I am aware of. Mostly stuck in the past with 4th Gen LT1 owners/experts.
ADMINISTRATOR
Old Apr 2, 2023 | 01:21 PM
JakeRobb's Avatar
Super Moderator
Just going by the text in your screenshots, it seems like the problem might be related to the camshaft position sensor on the bank 2 intake cam.
I’d suggest you consult the service manual (or equivalent, e.g. AllData). If you don’t have that, find a reputable professional mechanic.
Old Apr 2, 2023 | 02:14 PM
This is an extremely complex engine - direct injection, continuously variable valve timing, dual overhead camshafts, cylinder deactivation, etc. And poster appears to reside in Poland.
Old Apr 2, 2023 | 05:11 PM
henoh's Avatar
Thank you for your answer. is it then possible that it does not smoke only on 1 cylinder number 2 by the camshaft sensor? wouldn't it be a problem with more pots/banks?
unfortunately I don't live in the USA 🤔 we don't have many camaro specialists.
Old Apr 2, 2023 | 05:13 PM
henoh's Avatar
ADMINISTRATOR
Thank you for your answer 😀
Old Apr 2, 2023 | 05:16 PM
henoh's Avatar
Yes, I'm from Poland and I love Camaro. but i am confused by this problem. it was ok and suddenly he got his *** and something broke 🤔 and I thought the car was indestructible 😉. The injections are indirect because they go to the collector of what I know
Old Apr 2, 2023 | 05:20 PM
henoh's Avatar
would there really be a problem with only one cylinder through the sensor? Shouldn't be a problem for a few?. I was thinking about the shaft sensor because the problems are on bank 2 which has an inlet and outlet valve. I do not want to replace all the spark plugs, coils, injectors because I see that this is not the cause of the problem. The shaft sensor is just possible ... I thought about it.
Old Apr 2, 2023 | 05:21 PM
henoh's Avatar
by the way, can you use some engine flush because I have large deposits on the cylinders. ?
Old Apr 2, 2023 | 06:25 PM
According to GM the 3.6L LGX V6 has direct injection, “with the placement of the fuel injector in the combustion chamber.”
https://gmauthority.com/blog/gm/gm-engines/lgx/
Carbon buildup, particularly on the valves can be a problem with direct injection. So are deposits on the injectors, and plugging of the positive crankcase ventilation system. This can lead to further carbon buildup and misfires.
https://eeuroparts.com/blog/direct-f...hooting-guide/
Seems to describe your problems. I suspect this requires more than an “engine flush”.
What is required to clean everything up is not my area of expertise. While I am a licensed professional (mechanical) engineer, I have no experience at all with working on direct injection. I don't think there are any people here that do have that experience. I could be wrong. If we do, hopefully one of them will join this discussion.
Old Apr 3, 2023 | 04:12 AM
henoh's Avatar
this is very interesting information: "and plugging of the positive crankcase ventilation system." can you explain more? How to check or recognize it? supposedly the valves and all this crap can be cleaned with a special preparation or just kerosene?
What you are describing may actually be the cause. in the pictures you can see what the injection looked like, a similar mess is on top of the piston.
Thank you for the precise information.
Now i know i have direct. I will be grateful for any help and I hope that maybe someone who knows something more will join me.
Is there a service manual in pdf somewhere?
Old Apr 3, 2023 | 08:47 AM
I only know what I read in the article I linked, and from articles I have read in the past. I have no knowledge of what material would effectively remove the carbon buildup. You really need to find a website the deals with the newer engine technology.
The only online source of downloadable .pdf factory service manuals I am aware of does not have anything newer than 2001 models.
You need to understand, I am “in over my head” in solving your issues.
Old Apr 3, 2023 | 06:01 PM
henoh's Avatar
And thank you so much. If I fix it, I'll let you know unless I blow up the engine sooner ;😜
Old May 12, 2023 | 02:36 PM
henoh's Avatar
Hi. I just wanted to write that I solved the problem. the problem turned out to be the vvt control. 2 variable valve timing valves failed. They just blew up the oil pressure I guess. because they probably stopped working, the pressure went and burst them. replacing 2 vvt valves and the car works like this doll. valves cost $100 new in store $250. Thank you for your help.
Old May 12, 2023 | 05:59 PM
Thanks for the follow up. Interesting to know what the problem was. I'm surprised the PCM codes didn’t pick up the VVT issues.
Sad thing is, the only people left on this site are 4th Gen (1993-2002) owners.
