2010 - 2015 Camaro Wheels, Tires, Brakes, Suspension Discussion for 2010 - 2011 - 2012 - 2013 - 2014 - 2015 Chevrolet Camaro Wheels | Tires | Brakes | Suspension
[Suspension] Spohn G8/Camaro Trailing Arms and Toe Links
Old Nov 22, 2009 | 11:06 PM
Rob@WretchedMS's Avatar
New at Wretched: Spohn HD Trailing Arms and Toe Links
Available in Red or Black
Available in Steel or 4130 Chrome Moly.
Trailing Arms:
Toe Links:
Old Nov 23, 2009 | 11:07 AM
Prices vary for the different models, you can click on the pictures to go to the page for the part.
Note: just fixed the shipping on the parts, as there was no shipping selected before so the orders couldn't be processed. ooops
Old Nov 23, 2009 | 08:22 PM
Been asked by a couple people about these fitting with 16" Drag rims/tires on a G8, (Camaro should be similar depending on caliper clearance for the 16" wheels)
Originally Posted by Spohn
Our trailing arms should clear just fine. They are 1-3/16" from the center of the hole to the bottom the lower gusset plate, 1" to the area of the arm not gusseted (which would most likely be where the rim is).
If you look at this pic you'll see we kept it as low profile as possible, you could not have any more room as we're literally 1/8" clearance with the rear spindle.
Old Nov 24, 2009 | 04:20 PM
JasonD's Avatar
Admin Emeritus
What's the benefit to putting these on? Less wheel hop? Better handling?
jocamino
Jun 4, 2015 09:33 AM
87Aerocoupe
Jan 10, 2015 07:27 PM
Javier97Z28
Sep 8, 2002 07:23 AM
DrMilhouse
Aug 6, 2002 08:45 PM
Javier97Z28
Jul 24, 2002 08:13 AM
