2010 - 2015 Camaro Wheels, Tires, Brakes, Suspension Discussion for 2010 - 2011 - 2012 - 2013 - 2014 - 2015 Chevrolet Camaro Wheels | Tires | Brakes | Suspension
[Tires] rear tire size
Old Nov 30, 2008 | 01:01 PM
tgashie's Avatar
rear tire size
would 275/35/20 work on the rear of the ss?
Old Nov 30, 2008 | 04:05 PM
MetalDragon's Avatar
It would fit, but the stock tires are 275/40/20. If I did the math right, you would only end up with a half inch less sidewall (assuming that's what you're trying to do) while throwing off the overall diameter by about an inch, affecting speedometer and mileage by a good bit.
Old Nov 30, 2008 | 04:53 PM
TrickStang37's Avatar
I really doubt it would affect mileage at all. as it is, it's going to be chugging in 5th and 6th.
Old Dec 1, 2008 | 06:23 AM
Good point. And I just looked it up...you would only be off about 2.5 mph at 65.
Old Dec 11, 2008 | 08:54 AM
2010_5thgen's Avatar
why would you want to drop the side wall size of the tire without changing the rims size or width? just curious.
Old Dec 15, 2008 | 12:36 PM
2010SSVERT's Avatar
my neighbor did it to lower the car a bit(but it really made the ride a lot worse).
I am hoping a little wider tire will fit!
Old Dec 15, 2008 | 02:20 PM
For the price of the rubber...it would be cheaper to just buy a spring kit for it. The Eibach I have on mine ran me around $500 total.
Old Dec 17, 2008 | 05:16 AM
kookamunga's Avatar
wonder how wide a tire it will fit?
Old Dec 18, 2008 | 08:21 AM
im confused, are you trying to lower the ride height or widen the tires?
lowering the ride height, i would just get a lower profile tire, its not really going to lower it much at all. go with springs.
if your trying to widen the tire size, i heard that the size on there now is about as wide as they can go with out any changes to offset and backspacing. you can probably do a 285 without changing things but any wider and you may want to get a new wheel and change the offset.
Old Dec 19, 2008 | 01:25 AM
kookamunga's Avatar
actually as an F-Body autocrosser I was wondering if it will fit at least a 315 sized tire as thats what we run on all 4 corners on our 4th gen cars. seeing as this car is some 400#'s heavier I was hoping that it could fit somewhere in the order of 335 to 345 to make up for the additional weight. and at least a 315 up front. that's all
Old Dec 19, 2008 | 07:18 AM
sure, with modifications. theres not way your gonna lsap them on and expect it to not rub. anything can be done to this car. it just depends on how much you want to modify it. but they said the size on there now was about as big as you could go without cutting anything or modifying anything. i bet you could go up to a 285 in the rear atleast.
Old Feb 8, 2009 | 02:28 AM
kookamunga's Avatar
I hope it can take. As large a tire as the 4th gen. Currently we run a 315 on all 4 corners without any mode other than longer wheel studs, a1/8" spacer and a rolled outer rear fender lip. At 3800# it would need at least that much to be competitive I would think
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
Moshbmx1
Jan 20, 2015 03:27 PM
bossco
Nov 29, 2014 10:18 AM
