2010 - 2015 Camaro Wheels, Tires, Brakes, Suspension Discussion for 2010 - 2011 - 2012 - 2013 - 2014 - 2015 Chevrolet Camaro Wheels | Tires | Brakes | Suspension
[Tires] Rear tire size
Old Mar 7, 2008 | 07:03 PM
FUTURE TOP DOG OWNER's Avatar
Thumbs up Rear tire size
Who's hoping the large/small tire combo
275's on the front and 315's on the rear (at least for the top model!!)
would be my wish!!
Old Mar 7, 2008 | 07:48 PM
diarmadhi's Avatar
I'm going to need to rotate tires.. I'd rather have wide meats at every corner of the same size.
Old Mar 7, 2008 | 07:55 PM
wildpaws's Avatar
Ditto, I want all the tread on the road I can get at every corner of the car, I'm looking for all around performace, not some "cool look" best suited for 1320!
Clyde
Old Mar 8, 2008 | 05:56 PM
The "cool Look" And "1320" Comment Doesn't Make Sense!! If The Wider Rear Tire Set Up Was Only For The Quarter Mile Or Just
A "look" Why Would The Zo6 Wear A Set Of Wide Meats On The Rear!! If The Top Of The Line Camaro Is Going To Have A Speculated 500+ Horse (i'm Hoping) It's Going To Need The Most
Contact Patch To The Pavement As Possible!!
Old Mar 8, 2008 | 06:06 PM
Meatyshells's Avatar
i dont car what they use, as long as it's not those stiff as hell run flates they use on the vetts
Old Mar 27, 2008 | 04:08 PM
mpilarZ281992's Avatar
Again, car is to be "practical." Front/rear tire mismatch would not fit the practicality of the car. But yes, most supercars have the larger tire sizes for performance enhancement. But if you can afford a supercar (Z06 included) you just buy new tires more often.
Old Apr 2, 2008 | 11:14 PM
96' Formula WS6's Avatar
now I know that it was just a concept but I highly doubt they will have sepperate width tires. The new spy shots that just came out show a 245/45/20 pirrelli pzero tire.
Old Apr 3, 2008 | 03:31 PM
Z28x's Avatar
I'd like the see the LS3 car get 275/40/20"s as at least an option.
Pontiac G8 comes with P245/40R19 or P245/45R18
Old Apr 3, 2008 | 04:48 PM
DvBoard's Avatar
The camaro SHOULD come with a constant size tire to help reduce costs on replacing them by allowing them to be rotated properly. If you want otherwise, go aftermarket.
Old Apr 3, 2008 | 05:09 PM
wildpaws's Avatar
I really don't care what the Z06 has for a tire setup, wide tires (within reason) all around for maximum performance is what I want.
Clyde
Old Apr 3, 2008 | 09:15 PM
Maverick_997's Avatar
i know that i am probably the only one to saw this but i would like smaller tires on them for drifting cuz i really would like to see more muscle cars out thier liek mine drifting instead of those ****in rice rockets that have so little power they never have to play with the throttle.
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i54.photobucket.com/player.swf?file=http://vid54.photobucket.com/albums/g112/Maverick_997/Team%20STP/M2U00114.flv">
Old Apr 3, 2008 | 09:16 PM
wrong code
http://s54.photobucket.com/albums/g1...t=M2U00114.flv
Old Apr 8, 2008 | 03:43 AM
TrickStang37's Avatar
315's still arent enough for 500+ hp.
and if they do come with the 245/45/20's, they are going to need to run 3.80+ gears in the rear end to barely MATCH the old 3.42 set up. And if it revs any higher, gearing will be that much worse.
Old Jul 21, 2008 | 02:34 PM
AdioSS's Avatar
West South Central Moderator
Somebody wins a prize!
Man those are TALL tires!
Old Oct 13, 2008 | 05:45 AM
kookamunga's Avatar
hope it will fit at least 315's up front like the 4th grns for autox duty
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
Moshbmx1
Jan 20, 2015 03:27 PM
bossco
Nov 29, 2014 10:18 AM
