2011 2SS Tires
2011 2SS Tires
About to replace the stock P-Zero tires of Front 245/45-20 to Nitto INVO 255/35-20 and Rear stock 275/40-20 to Nitto INVO 295/35-20 and place on the stock 20"rims. Does anyone foresee a problem? Thanks.
Re: 2011 2SS Tires
I'm relatively sure you have the inner clearance with a 20" on the rear with stock offsets, you wouldn't with smaller diameter wheels. My concern with the rear would be you're mounting a tire designed for a 10.5" wheel on a 9" wheel, which is 1" outside of the approved rim width for a 295/35... everyone rolls there eyes at approved rim widths, but if you've ever seen a tire pull off a rim while cornering, it matters and can ruin your day... I'd just be aware of that.
cmsmith
Sep 14, 2015 09:25 PM
Aug 5, 2015 08:35 AM
