where can i buy LEXAN front and rear windshields?
Old Mar 25, 2012 | 04:47 PM
ls427ray's Avatar
Old Mar 28, 2012 | 05:56 AM
JasonD's Avatar
Admin Emeritus
Re: where can i buy LEXAN front and rear windshields?
WOW...you are nuts.
Tough call...haven't seen them offered. Summit or Jegs?
Old Mar 28, 2012 | 07:21 AM
ls427ray's Avatar
i want to lose the heavy glass. 100 pounds = 1 tenth at the track
Old Mar 28, 2012 | 09:10 AM
Wild Willy's Avatar
Not street-legal, need to be DOT approved- which they wouldn't be. Not a big deal in back, in the front it might be. Not to mention that Lexan is pretty soft, and prone to getting scratches in it. Easier ways to get weight out of a car. Gut the interior. lighter wheels and tires.
Old Apr 1, 2012 | 08:45 PM
MikeGyver's Avatar
lmao... the second you use your wipers will will scratch the hell out of it. polycarbonate is soft and very flexible.
Old Apr 1, 2012 | 08:58 PM
JasonD's Avatar
Admin Emeritus
I don't think he will drive it in the rain. It may not even have wipers...
https://www.camaroz28.com/forums/f-b...camaro-839683/
Old Apr 2, 2012 | 02:25 AM
MikeGyver's Avatar
That's pretty crazy. If you're not using wipers it could be made to work on a track car. I made a 1/4" thick Makrolon (polycarbonate) rear window on my wrangler hardtop and it scratches so bad I have to buff and wax it every year, and I try not to ever touch it unless i have to clean it. I would never want the stuff for the front where you have to see out of it, at least on a daily driver. There might even be some sort of laminate coatings that are harder which would offer scratch resistance.
My rear window is floppy when I lift the 'tailgate' glass. Up front on a fast car where it's got a ton of pressure on it from high speeds, you'd have to put some sort of curve into it at least or it might do some really weird stuff.
Maybe I'm wrong but isn't the 1/10th per 100lbs more for stockish vehicles, or does it apply the same to vehicles with a drastically different power-to-weight ratio?
Old Jul 23, 2012 | 04:36 PM
TedH's Avatar
Actually, it applies to pretty much everything, including fuel dragsters and stock vehicles...
Old Aug 1, 2012 | 12:36 PM
JasonD's Avatar
Admin Emeritus
I was just reading FSC magazine at work, and saw an ad for this company:
Optic Armor Performance windows
The ad says they have drop in 4th and 5th gen Camaro lexan windows.
Jazsun
Dec 29, 2014 12:14 PM
Dec 4, 2014 11:56 AM
siguy
Nov 27, 2014 10:07 AM
