slight clunking noise in tranny / drive line
Hey guys, I've been experiencing a clunking noise when I disengage the clutch and get the car rolling in first, and second gear ( kind of sounds like a worn "U" joint ). I brought it to my dealer, and was told that this is normal for these types of drive lines ( I'm not so sure ). Has anyone else experienced this, or is your car smooth, and clunk free ?
LS3 with the T6060 transmission
if you have windows open you will hear it....these are big beefy transmissions that are built to handle massive torque and when you shift at slow speeds or release the clutch you may hear some sounds. I would not worry a bit. Transmission is one of the strongest components on this car.
I dont really buy in to that, it's a dead stock production car not a proshifted race car with a spool. My Sierra had a slight clunk in the driveline and it's only gotten worse with miles, I'll be taking it in for warranty. Your dealer just most likley hasn't seen to many yet for this so their being lazy.
My car also makes a slight clanking noise like you are experiencing. I was wondering WTF is this? At first I thought because my car had 24 miles on it when I took deliverly that someone drove it too hard!
My dealer told me that sometimes they pick cars at random for testing purposes and this was probably the reason for the 24 miles. I'm taking it in for sertvice and will let you know what I find out!
Look for a TSB on it, if other people have the exact same problem, it isn't a problem with your car only. With a car this new, any issues you run in to, other cars will most likley have issues with it too.
Asked the dealer about this noise. They just printed a GM document that says "it's normal" GM says if they handed me a paper on it, it's been decided by GM it's normal and they won't address the issue.
As long as it doesn't get worse, I'll just turn up the tunes.
Hey Guys
I have had a few words with my dealer and his so called ace mechanical supervisor about this noises coming from the tranny back late last year. I made them lift me up in my camaro so that I can make this noise and they can track it down, it is coming from inside the tranny. I had them contact the factory engineering group to get an answer to this issue. their response was: it is not a performance issue so there is nothing they will do about it. the noise is not enough to warrant a Recall on it. So we are stuck with this irritating noises until all of us make enough noise back at them so they will do some thing about it. As far as I am concerned this "Reborn All American Muscle car" should not have been designed/engineered with a clunking noises in the tranny. I am some time embarrass to give my friends a ride because of this noise. The first thing they say is" what is that NOISE?" And what am I suppose to say???? I absolutely Love Camaros and I love My New 2010 Camaro!!!
I hear it all the time when I push in clutch on a bit of a hil or shifting close to a wall where you get reverberation....turn up the radio...close the windows and deal with it...these are strong trannies and it does not concern me.
bought a big warranty just in case....
Re: slight clunking noise in tranny / drive line
This is an annoying problem for us GTO guys. It is known as the notorious "drivetrain slack". It can be downright embarassing at times to be honest, but I have learned what circumstances cause it and try to avoid them. Pressing down the clutch pedal when slowing down in first is a big culprit. You hear a pretty loud audible thunk or clank. My dealer said it was normal for the cars with this amount of power and an IRS. I don't know the mechanics of it. All I know is that it doesn't happen in my Firehawk, but that car doesn't have IRS either.
edman
Jan 22, 2015 02:45 PM
squarehead
Nov 21, 2014 08:02 PM
1LEThumper
Jul 14, 2003 12:45 PM
... they all had it ... it wont hurt just learn to live with it..it is typical GM quality noise ..
