Service Stabillitrac at Startup
Seen in twice now, where the car shows a Service Stabillitrac message on the DIC at start up, then it vanishes right away. Has anyone else noticed this?
Re: Service Stabillitrac at Startup
I usually run into this with my Corvette if I'm backing out of a shopping center parking space. When it happens, I just shut off the ignition, restart and drive straight forward a very few feet and the verification is just fine.. There may be a different boot sequence now which retries to establish steerning wheel position and that is why the warning is turning off as it's run the test again without the need to shut off the ignition as was once the case.
If this isn't scenario isn't what is going on in your instance?, see your dealer.
Actually, I did a little searching and found somewhere else that said it happened to them only if they 'flicked' and released the key from the Start position. (IE: turn it to start, then fall back to On before the car is actually running)
So I've been keeping my eyes on it, if I turn the key to Start and hold it there until the car is started, it doesn't seem to have this issue.
Nayr
Mar 3, 2023 08:34 PM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
