need wheel hop help
Old Mar 20, 2010 | 10:17 AM
powerhog's Avatar
need wheel hop help
I put on a CAI on my 2010 LS3 camaro and found it to be a worth while Mod. I could'nt believe the response, now I have wheel hop with both the traction control and the stabilitrac turned off, whats offered to elimanate wheel hop while getting on it hard from a dead stop?
Old Mar 21, 2010 | 10:06 AM
powerhog's Avatar
P.s.
went with BMR trailing arm, also Borla S-type, skip shift, aint this fun!
Old Mar 21, 2010 | 02:58 PM
JasonD's Avatar
Admin Emeritus
I thought the trailing arm was supposed with help with wheel hop.
Old Mar 22, 2010 | 09:47 AM
2010_5thgen's Avatar
i put BMR trailing arms and toe rods on my car. it helped for sure. i also did the subframe connectors.
Old Mar 22, 2010 | 12:51 PM
powerhog's Avatar
sub-frame connectors???
I am not sure what sub-frame connectors and tie rod ends do, I do not road trac race, I want the wheels to stay down on the pavement when I launch, it seems the traction control and stibilitrac rob power so I turn it off. Please explain?
Old Mar 22, 2010 | 02:53 PM
subframe connectors just tighten up everything underneath. helps alot in quick cornering and i dont see how it wouldnt help when transfering weight to the rear wheels on a launch.http://www.bmrfabrication.com/F5.htm
force10
Aug 10, 2015 08:30 AM
240ssLs3
Jul 13, 2015 05:06 PM
Slayer
Jul 4, 2015 03:06 PM
SAR2K
Sep 1, 2002 10:49 AM
wytblur
Aug 5, 2002 02:03 PM
