ls3 ss 430hp!!!
Old Dec 11, 2008 | 03:42 AM
  #16
samrawet's Avatar
thanks for information
Old Dec 11, 2008 | 04:27 AM
  #17
TrickStang37's Avatar
Originally Posted by Geoff Chadwick
The C6, G8, and Camaro all have true dual exhaust with an X pipe, and from the pics I've seen all appear to be a similar diameter pipe with similar number and quality of bends.
Power under the 430hp mark is due to either (a) its 430hp and they just mark it less to keep vettes happy (b) due to really bad mufflers and/or cats (c) exhaust manifolds that are terrible or (d) a de-tune.
Awesome looking G8 underside shot for reference
it will not be underrated. the engine is going to SAE certified and, therefor, impossible to be underrated.
Old Dec 11, 2008 | 08:57 AM
  #18
JakeRobb's Avatar
Super Moderator
Or (e), a more restrictive air intake.
SAE certification prevents overrating, not underrating.
Old Dec 11, 2008 | 01:13 PM
  #19
93Phoenix's Avatar
Seen the 08 Vettes dyno? About ~390 is common, with a 15% loss which is commonly used for the T56/RWD platform that's 461 hp.
Old Dec 11, 2008 | 07:33 PM
  #20
you obviously have not read about the SAE certification process and it's rules. go to their website and check it out. it prevents both underrating and overrating. its +-1%.
Old Dec 11, 2008 | 07:35 PM
  #21
15% is obviously wrong then. its closer to 11-12%, and maybe even less on high powered engines. There's no way around the SAE certification Horsepower number. check out their website.
Old Dec 11, 2008 | 08:54 PM
  #22
JakeRobb's Avatar
Super Moderator
15% is a ridiculously high amount of drivetrain loss for a T56. That amount may be "commonly used," but only by those who assume that a T56 is no more efficient than a traditional 4- or 5-speed manual.
Also, the '08 Vette uses the TR6060, which is the successor to the T56.
On a stock LS1 M6 F-body, 12-13% loss is typical. As horsepower increases, expect the percentage loss to decrease.
Old Dec 12, 2008 | 10:28 AM
  #23
JakeRobb's Avatar
Super Moderator
Originally Posted by robvas
Wrong again. It actually increases.
It increases for automatic transmissions. We're talking about the T56 / TR6060.
I don't have the data handy, but I've seen proof that 400bhp through a T56 and a 9" yields a higher percentage of drivetrain loss than 500bhp through the same drivetrain.
Old Dec 12, 2008 | 03:17 PM
  #24
It takes more work to do something faster. There's also more drag, etc at higher speeds.
just proportional gains will do that.
and drivetrain losses is different than aero losses.
I have also seen higher hp cars lose less through the drivetrain proportionally than lower hp cars. nothing major, like 2%.
Old Dec 12, 2008 | 03:37 PM
  #25
JakeRobb's Avatar
Super Moderator
I'm not arguing physics, I'm arguing results. As I said, I've seen proof. (IIRC, it came from Injuneer.) If you have data to the contrary, I'm all ears.
Old Dec 14, 2008 | 11:56 AM
  #26
Eric Bryant's Avatar
I got a PM asking if I could stop by this thread and make a comment.
There are three general types of losses:
1) Frictional. This will tend to be proportional to the increase in torque in the gearbox, and the increase in speed.
2) Viscous. These losses increase only with speed, and tend to be much less significant than frictional losses at the sort of loads and speeds that we're talking about with automotive gearboxes (the same might not be true when talking about devices that operate at much higher speeds and much lower loads).
3) Inertial. These losses are proportional to the rate of acceleration, and aren't really "losses" in the sense of talking about steady-state power losses - but since inertia dynos are dynamic in nature (as is real-world driving), they must be considered.
If the viscous losses dominated the measured losses in the powertrain, then it'd be possible that increasing the engine output might result in a decreased in measured losses (just so long as the rotational speed of the drivetrain elements didn't increase). But typically, frictional losses will dominate the measured losses in the powertrain, and so it's highly unlikely that the overall powertrain efficiency will increase with more engine output - in fact, the opposite is likely to occur.
I'd love to see data that shows the opposite effect. I suspect that there are test abnormalities, minor measurement errors, or other changes in the vehicle setup that would make it very difficult to make an apples-to-apples comparison that shows a net decrease in the percentage loss incurred in the powertrain.
Put in simple terms - more power is going to almost always mean proportionally greater losses.
Old Dec 15, 2008 | 08:21 AM
  #27
JakeRobb's Avatar
Super Moderator
Makes sense... I guess I'll have to ask Fred to confirm/deny my memory of his results.
Old Dec 15, 2008 | 10:53 PM
  #28
My tests - engine dyno vs chassis dyno - showed:
McLeod Street Twin/Steel flywheel/T56/3" CM DS/Strange 12-bolt/3.73:1/17x9.5 OZ wheels w/ 275/40-17 GS-C's:
NA: 486 flywheelHP / 425 rwHP = 12.55% loss
1-stage N2O: 635 flywheelHP / 557 rwHP = 12.28% loss
2-stage N2O: 765 flywheelHP / 672.5 rwHP = 12.09% loss
TH400/5000rpm flash, non-locking converter/3" CM DS/Strange 12-bolt/4.11:1/17x11 ZR1 wheels w/ 315/35-17 BFG DR's:
NA: 486 flywheelHP / 390 rwHP = 19.8% loss
1-stage N2O: 635 flywheelHP / 507 rwHP = 20.2% loss
2-stage N2O: 765 flywheelHP / 602 rwHP = 21.3% loss
One complication.... on an engine dyno, the RPM/sec acceleration can be controlled at a constant value, standardizing the inertial losses. On a DynoJet, a more powerful engine will accelerate faster, increasing the inertial losses.
Old Dec 16, 2008 | 08:27 AM
  #29
JakeRobb's Avatar
Super Moderator
Thanks, Fred. I'm glad to hear that my mind isn't playing tricks on me.
Eric / anyone, does the complication Fred mentioned explain the anomaly?
Old Dec 16, 2008 | 11:04 AM
  #30
JakeRobb's Avatar
Super Moderator
You're measuring 2 different things, 2 different dynos
Do you have a better way to measure drivetrain loss than with two different dynos?
Different run times, not to mention the differences are VERY small in some cases
True. It's also a very limited data set. There is a consistent trend, however, and I have yet to see anyone post actual results that indicate otherwise.
