LS3 (base V8) info leaked from recent meeting in Durham ?
Of course it's from an indirect source (at least that's how it appears), but this camaro5 member claims that his cousin was in attendance of a recent executive meeting in Durham and that the LS3 will be the V8, V6 DI engine, with 4 piston front brakes.
source:
http://www.camaro5.com/forums/showthread.php?t=2941
source:
And though this isn't 'official' info...it does sound about right....
I've have believed the base V8 would be the LS3 for sometime. Just makes sense IMO. And the spy pics of the engine seemed to be a copy of the 3.6 DI engine cover used on Caddy's variant.
Interesting to hear about the race only Camaro. That's news to me. Dodge has already made plans for the Challenger to have a race only model and now Chevy has a Camaro. Wonder if they will someday meet in a sanctioned and lightly corp. sponsored event. Return of Trans Am...
i would think his "couzin" Jared would get canned if this information was legit. He posted all his info too.
("resides in the rural whitby region and is a senior member of the oshawa based GMNAAC he has worked in and around the oshawa GM plant...")
Most of the things that he said are things that we (meaning most people on this board) have already mentioned. LS3, location of gas filler door, 4 piston brakes, remote start on the key fob, etc. Aside from obvious things, like pre-pro vs. production, location of gas filler door, etc., I'm not getting my hopes up on anything until I hear it from Scott.
Same here, this quote and the other stuff about his dad with the Viper, gonna trade it in on a ZR1 and blah, blah, blah...
Along with this
one more thing...all new rear suspension setup on the mustang much like the shelby
I'm pretty sure everybody here knows a Shelby doesn't employ anything special when it comes to the rear suspension. Its the same 3-link found on all current Mustangs using stiffer bushings, bigger axle bearings, and posibly a stronger 3rd member case. Thats it, matter of fact the Bullitt uses the exact same rearend.
I have believed this since speculation began. Although I typically wouldn't believe a post like that, I believe what is posted in this one. Also, to validate Fbodfather's "forget all you know about engines comment", I believe this version of the LS3 will have active fuel management since gas will be $4 by the time this car meets the road.
I sure hope they put some huge tire-smoking V8 in there for you guys.
I think I'm going to be pretty happy if I buy one with the DI 3.6.
I'm also secretly hoping for an OMGWTFBBQ engine option like a diesel 6 cylinder, or a hybrid/electric setup but that's pretty much NOT going to happen.
