Horsepower peak @ 5000RPM
Old Jul 21, 2008 | 01:59 PM
AdioSS's Avatar
West South Central Moderator
This is either a misprint or maybe the folks at GM are being sneaky. Yeah, it only makes 422/400hp@5000RPM (but it makes 440hp@5800RPM.)
I mean, look at the torque peak at 4500.
In the 2009 Corvette, the peaks (with standard exhaust) are 430hp@5900/424tq@4600. Preliminary specs of the G8 GXP LS3 indicate 402hp@6000/400tq@4400.
The only catch that I could see is if it uses variable valve timing, but that's not listed anywhere in the specs.
I can't wait to see the SAE ratings.
Old Jul 21, 2008 | 02:21 PM
JakeRobb's Avatar
Super Moderator
What are you referring to? I didn't see anything about 440hp.
Old Jul 21, 2008 | 02:28 PM
AdioSS's Avatar
that was an example. I don't know what it really makes at 6000RPM.
The DZ302 was only rated at like 290hp despite obviously making more than that, right? Many people joke that it was rated at an RPM lower than where it's peak power really was. I'm suggesting that maybe that idea is being used here also..
Old Jul 21, 2008 | 04:00 PM
radz282003's Avatar
Regardless if there is underrating going on, I think it is agreable that 420 horse' is pretty d@mn good. If I can't get a Z28 in a few years, I wouldn't be too sad with this power. I think they're doing a great job thus far.
Old Jul 21, 2008 | 05:06 PM
HAZ-Matt's Avatar
The LS3 doesn't have VVT. If the motor is identical to the Vette motor then the only differences would be the chassis specific exhaust components.
I am more concerned about the L99 in the automatic and how much difference in performance there will be between it and the LS3 cars.
Old Jul 21, 2008 | 06:00 PM
dacook's Avatar
Exactly.
Old Jul 21, 2008 | 06:41 PM
99SilverSS's Avatar
I think it's a misprint I would have expected the HP peak to be in the 5900-6000 range like the LS3 in Vette and G8 GXP.
The 3.6L DI is listed at 300hp at 6400.
Old Jul 21, 2008 | 09:45 PM
teal98's Avatar
It has to be a misprint.
422hp at 5000RPM is 443 lb ft of torque. Yet the torque peak is 408. So there's something fishy.
Old Jul 21, 2008 | 09:59 PM
HAZ-Matt's Avatar
Originally Posted by dacook
Exactly.
Well the official GM performance numbers show the automatics to be quicker in the 1/4 then their respective manual models. That is a little odd. They said they "optimized the shift points." Guess torque converter plus the gearing difference makes up for 20 less HP, more weight, and 600 less revs.
Old Jul 22, 2008 | 12:22 AM
teal98's Avatar
Do you have a URL for those numbers? I've not seen any numbers for the Camaro yet.
Old Jul 22, 2008 | 01:05 AM
Jason Dove's Avatar
1/4 mile times etc are here:
http://www.edmunds.com/insideline/do...ticleId=129496
Old Jul 22, 2008 | 01:16 AM
teal98's Avatar
Originally Posted by Jason Dove
Thanks. It looks like the A6 is very efficient.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Aug 24, 2015 06:41 AM
Slayer
Aug 17, 2015 03:55 PM
karpetcm
Aug 14, 2015 03:02 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
