2010 Camaro Exhaust Options
Ok guy/girls...our long awaited car is almost here. I like many others cannot leave well enough alone when it comes to my cars. One of the first changes to my 2SS will be a mean sounding set of mufflers. I have always been a Flowmaster fan, but want something different this time around. I have narrowed it down to Corsa, with the aggressive black mufflers, or SLP loudmouth set up. I like loud muscle cars. Does anyone have any thoughts on these 2 systems, experiences, feedback, other suggestions.
borla has designed the gmpp system for the camaro so im sure they are and will be the first to have a system out for the camaro.
i plan on doing the borla catback system and probably hooker long tube headers. just to give it that deep aggressive sound.
2. You haven't heard the Camaro's exhaust yet.
3. You have no idea on how efficient the Camaro's exhaust is.
One of the hot rodding mags got ahold of a Challenger SRT8, and (like you) the first thing they did was install an aftermarket exhaust.
Funny thing.
The aftermarket exhaust was more restrictive than the one from the factory. Turns out, the aftermarket exhaust had a smaller diameter than the aftermarket one. If I remember, I've also read that the Challenger SRT8's mufflers are perhaps better than any available aftermarket item.
Both cases, it was Borla.
Wait till it's actually in showrooms and you've heard the exhause tone yourself and read about how efficient it is (or isn't) before blowing that hard earned money that might have better use elsewhere in the car.
1. The car is still 3 months from ending up in the showroom.
Funny thing.
Funny thing.
Funny thing.
Funny thing.
I promise that welding a set up Dynomax or equivilent bullet mufflers will outflow, make the car louder, and be cost effecient.
May not be everyones cup of tea however. If GM runs a 2.5 inch true dual system stock you will have enough pipe to support 500 hp or so.
But until you add the required mods, you'll be down on torque numbers due to the huge 3" dual exhaust on the factory setup.
I would stick to either a muffler sawp/muffler delete until the new mods are done. Heads/Cam, cold air, and a set of long tubes would get you close to actually using the dual 3" exhaust, but ideally, yoiu would be looking at stoker or forced induction to need that kind of exhaust flow. If the cats are as efficient as the ones on the new Vettes, then you won't gain tons of power form cutting them, just more noise.
3" is a good diameter for a single I-pipe, but oversized for a true dual exhaust unless your pushing serious horsepower. As mentioned above, you'll be less efficient with a system that large without a serious head/cam or power adder (ie. s/s, nitrous, turbo).
