Zeta Rear Axle?
Old Mar 18, 2008 | 03:45 PM
skorpion317's Avatar
Zeta Rear Axle?
Anyone know how big the Zeta rear axle is? I hope it's bigger than the 10-bolt in the 4th gens. I can't find this information anywhere.
Old Mar 18, 2008 | 04:52 PM
TrickStang37's Avatar
i looked into it as well. i did read of the australians having issues with wheel hop on the zeta platform tho.
Old Mar 18, 2008 | 08:22 PM
2010's Avatar
The 04-06 GTO used a Dana 44 center section. I think they beefed it up a little from the standard Monaro model. Still isn't as big as I'd like to see though. Anyway, I'm guessing it's the Dana 44
Old Mar 18, 2008 | 08:23 PM
cmg06s's Avatar
would it be the same axle thats on the G8?
Old Mar 18, 2008 | 08:58 PM
POWERFREAK's Avatar
I would think so.
Old Mar 19, 2008 | 07:32 AM
I was just doing some research, and apparently, the GTO/Monaro's rear axle was a Borg-Warner Australia design, called the "M80"
Dana bought Borg-Warner's Australian axle division, so now the axle is considered to be a Dana. It's not a Dana 44.
The M80 is an 8" 8-bolt. It's not particularly strong, and no one makes ring and pinion gears numerically higher than 3.91. I pray to God that this isn't the axle that Zeta uses.
Old Mar 19, 2008 | 07:36 AM
More news - according to Ward's Auto, because Dana went bankrupt, Holden did not use their axles in the new VE Commodore. Instead, they use a ZF axle. I'll try and find out which one it is.
EDIT: The ZF axle is an 8.3". Apparently, there is a ratio limit of 3.70. It's supposed to be durable, but they don't stand up to prolonged abuse.
Old Mar 19, 2008 | 08:45 AM
POWERFREAK's Avatar
Isn't that an oxymoron??? "It's durable but it doesn't stand up to prolonged abuse"
Old Mar 19, 2008 | 02:24 PM
I'll clarify.
ZF's products have a reputation for being durable. However, in the VE Commodores, people have already broken the rear axles. It does not appear that the Commodore's ZF axle is as durable as their products in other applications.
PROJECT X
Apr 17, 2015 12:13 AM
QuickSilver02
Apr 7, 2015 11:12 AM
4586
Jan 3, 2015 07:22 PM
rockync7
Jan 1, 2015 05:10 AM
