Zeta Rear Axle?
Dana bought Borg-Warner's Australian axle division, so now the axle is considered to be a Dana. It's not a Dana 44.
The M80 is an 8" 8-bolt. It's not particularly strong, and no one makes ring and pinion gears numerically higher than 3.91. I pray to God that this isn't the axle that Zeta uses.
More news - according to Ward's Auto, because Dana went bankrupt, Holden did not use their axles in the new VE Commodore. Instead, they use a ZF axle. I'll try and find out which one it is.
EDIT: The ZF axle is an 8.3". Apparently, there is a ratio limit of 3.70. It's supposed to be durable, but they don't stand up to prolonged abuse.
ZF's products have a reputation for being durable. However, in the VE Commodores, people have already broken the rear axles. It does not appear that the Commodore's ZF axle is as durable as their products in other applications.
