Water Pump Replacement
Old Jun 6, 2007 | 08:05 AM
DLancer7676's Avatar
Good morning! I am a newbie on this list. This is my 2nd post on this topic but I am not sure the first post got through. I have a 1994 Camaro Z-28 with the 5.7 L. Engine and I need to replace the water pump, which I have ordered. The old one is pouring water out of the weephole. I have a Haynes manual and it outlines the method of replacing the water pump. I have one question:
As I have disabled the airbags and have removed the upper panels over the water pump area already, I am ready to lower the fan assembly out of the automobile to remove it. As I look at it, it doesn't look like I have to remove the radiator to remove and replace the water pump, although Haynes says I do. My question is, is it necessary that the radiator be physically removed to replace the water pump, or is there enough room to do the job with it in place?
Thanks for any assistance. Any other caveats will be welcome too.
Old Jun 6, 2007 | 08:23 AM
JasonD's Avatar
Admin Emeritus
It did go through, it is right here:
http://web.camaross.com/forums/showthread.php?t=524393
This is the 2009 Camaro engine forum, the first thread you started was in the correct forum.
Welcome to CamaroZ28.Com!
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
pologreen97z
Dec 2, 2014 10:42 AM
