Dead pedal???
Old Oct 8, 2008 | 02:10 PM
CTK1's Avatar
Dead pedal???
In the Camaro workbook it lists a "Dead Pedal", what are they talking about???
Old Oct 8, 2008 | 02:12 PM
JasonD's Avatar
Admin Emeritus
The pedal for your left foot to rest on when not in use. It is a good thing.
Old Oct 8, 2008 | 02:14 PM
CLEAN's Avatar
Originally Posted by JasonD
The pedal for your left foot to rest on when not in use. It is a good thing, the 4th gens only had a flat area and not an actual pedal.
Or you can use it to mash yourself into your seat during "spirited" cornering
Old Oct 8, 2008 | 02:15 PM
Rob V's Avatar
From Wikipedia...
In an automobile, the dead pedal is located to the left of the other pedals. Unlike the throttle, brake or clutch pedal, the dead pedal does not move and is not connected to anything. The dead pedal can serve several important purposes:
It acts as a foot rest for the left foot.
In cars with manual transmissions, it helps keep the driver from riding the clutch.
It helps brace the driver whilst performing extreme maneuvers.
http://en.wikipedia.org/wiki/Dead_Pedal
Old Oct 8, 2008 | 02:16 PM
5thgen69camaro's Avatar
I dont know about anyone else but I didnt like the 4th gens dead pedal. My foot kept sliping off it. I hope this one is better...
Old Oct 8, 2008 | 02:24 PM
jg95z28's Avatar
You must have huge feet. I'm a size 12 and I've never had that problem.
Old Oct 8, 2008 | 02:56 PM
CTK1's Avatar
Thanks for clearing that up for me. I don't know that that piece of equipment needed to make it into the workbook, not exactly a highlight IMO.
Old Oct 8, 2008 | 04:40 PM
MissedShift's Avatar
Drive a manual transmission car long distances in traffic without one, and come back and let me know if you feel the same way...
Old Oct 9, 2008 | 10:53 AM
Koz's Avatar
Koz
I don't ever use mine for normal driving
I don't have any issue with it, just saying...
Old Oct 9, 2008 | 02:47 PM
97QuasarBlue3.8's Avatar
It's really not a highlight. Dead pedals aren't exactly "common" equipment in GM cars though, so maybe they're listing it so they appear as hip and cool as other performance car makers. Usually what you see is a patch of vinyl on the carpet as a place to rest your foot, or there's a foot e-brake that swings down there.
Dead pedals are great. If you're a spirited driver, they provide you a place to brace yourself. For everyday driving, they're great especially with manual trans cars-- 1) It discourages you from resting your foot on the clutch and burning it up, and 2) it provides a level "platform" so your left and right feet are extended at approximately the same distance. This is better for your back.
4th gens had them, but they weren't very good as I remember. Smallish, made of plastic.
Old Oct 9, 2008 | 03:17 PM
Not unless you consider size 12 huge. It was worse when it was raining or snowing. A problem I havent had in other cars. I thought it was due to the angle and the thing having no grip. I thought it was annoying.
Old Oct 9, 2008 | 07:27 PM
bigsjk's Avatar
dead pedal? drive a G8
Just test drove a G8...has the dead pedal, but I will call the accelerator a dead pedal too as it was so close the brake pedal my foot got stuck and I almost crashed!
Old Oct 11, 2008 | 07:28 PM
Steve in Seattle's Avatar
Post
The location was perfect and there was plenty of room. I had a MBA billet aluminum cover on mine that enlarged it a bit and gave it diamond-grip... perfect solution.
The key to a good dead-pedal is to be BIG, and comfortable with plenty of grip. Having it as close to the clutch pedal as possible is also a great help.
Old Oct 11, 2008 | 07:32 PM
Post
Perfect heal-toe pedal placement is what you're describing, the opposite (a wide gap used in work trucks) is more comfortable for large boots or those with less co-ordinated feet. As the population ages you'll probably see these gaps get wider, making heal-toe shifting in manuals more difficult without installing pedal plates.
Were you wearing boots when you had this foot-pedal problem? do you push with your toes, or ***** of your feet?
Jlo
Jul 29, 2015 03:52 PM
surreybrad
Jul 5, 2015 10:36 PM
andrewcapps82
May 19, 2015 10:11 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
