[Interior] New Interior Shots!
#31
If you notice, there is no key in the ignition. *If* the picture taker pulled the headlight switch the cluster should be much more lit than it is. I think the "bright halo glow" is nothing more than the camera's flash reflecting off the surface. Same with the console gauges, it looks like they're "lit" with the flash.
#32
Since we don't see any gage check lights in the center section, it's a good possibility.
#33
As for the console gauges - I do think those were in steady-state illumination at the instant of capture. Maybe he had the key in for the console shot, then pulled the key, then took the speedo/tach shots during the 'afterglow' period. Sort of like a "ooh! look at that!" shot.
#34
Seeing your post - I just thought of something! I've noticed a lot of cars nowadays 'do a little show' when you do certain things either in startup or upon key-out. For example, when I first start up my GP GXP - the first thing that shows in the HUD for a second or two is a big graphic, "G P". When you shut the car down and pull out the key, several things happen. The theater-dimming dome lights come up like at the end of a movie... the fog lights and backup lights illuminate... odometer illuminates... and so on. Maybe what the (now-fired I hope) spy cameraman shot there was a little halo showoff feature that happens upon key-out.
#35
#36
#37
Have you spent an extended amount of time behind the wheel of a car with gauges using that font?
...My Grand National has a speedometer that is only marked every 20mph. I hate it. It's difficult to tell the difference between 45 and 55 at a glance, and I'd really rather not get a 10-over speeding ticket because I don't have a well-labeled speedometer.
...If GM changes to a more appropriate font, I think I could get by with the 20mph increments. If GM changed to 10mph increments, I think I could get by with the skinny font. I really don't want to deal with both.
I'm confident that there will be a HUD with a digital readout, so I will most likely not have any issues with knowing my speed at a glance. Having said that, I firmly believe that every road-going car should have an easy-to-read dial speedometer, and the interior shown doesn't.
I'm sure that a replacement gauge or at least an overlay will be available from the aftermarket, so this isn't a huge problem or a deal breaker for me. I just want my opinion to be known and understood.
#38
#40
i knew someone was going to bring that up... if it was with a build in flash from a camera phone then you would have gotten better view of the dials... because the direct light source... meaning you would have had better view of the numbers since the light bounces directly from that "flat" surface. There was NO flash in that picture.
#41
#42
Not that bad actually, (crappy camera!)hopefully there's a dimmer switch for the halos...
Just kinda make those squared bezels seem out of place now, I wonder how a more rounded set would look??
Maybe if the outside-top was angled down a few degrees, or a symetrical bevel opposite the lower inside ones, might've looked better.
#45
This is me saying something nice.
The blue backlight on the main gauges seems to be traced in red, which mimics the red backlighting on the ***** on the radio. That's good attention to detail.
Maybe it won't wind up looking so cobbled together, but I can't imagine how they are going to make those huge ***** with 88 functions match the retro theme. In fact I would hate to see whatever does match them...
