What are the symptoms of a bad coil on a 3.8L V6?
Old 03-31-2004, 08:34 AM
Gripenfelter's Avatar
Its my wife's '97 GTP.
Gripenfelter is offline
Old 03-31-2004, 08:56 AM
hawgs's Avatar
The cylinders of that coil not firing...
Go buy a new coil and put it on and see if it fixes it. They're very easy to install. If it doesnt fix it return it.
hawgs is offline
Old 03-31-2004, 09:52 AM
My wife has a misfire in her car.
Can't track down which cylinder it is but it sounds like its skipping one cylinder.
Old 03-31-2004, 11:21 AM
hawgs's Avatar
anyway you can gain access to Autotap? If its a bad coil pack shouldnt it will be missfiring more then just one cylinder?
hawgs is offline
Old 03-31-2004, 01:51 PM
Yes it should be 2 cylinders.
Old 03-31-2004, 03:55 PM
hawgs's Avatar
Start the car and go plug by plug on the coil pack and unplug them. The one that you unplug and it makes no difference in the idle of the car is the one that is bad. Try moving one of the other coils onto this spot and plug everything back and see if its the same plug giving you problems. This will rule out the coil pack being the problem if so.
If it is still the same cylinder pull the spark plug out and look at it and see if it is fouled. If its fouled you have a lot bigger problems then just a messed up coil pack.
hawgs is offline
Old 04-02-2004, 07:31 AM
Amped96's Avatar
If you have a haynes manual, it will tell you how to test the coil packs with a volt/ohm meter. My 3.8 went through a couple sets of wires and a couple coil packs before we just replaced everything with MSD stuff. 3.8s seem to eat some ignition products.
From my experience, a bad coil pack had the same symptoms as a burnt plug wire.
Amped96 is offline
Old 04-02-2004, 03:38 PM
Misfire cured!
Was a bad coil.
Old 04-02-2004, 10:54 PM
Need4Camaro's Avatar
I still need to heat sheath my wires...
I had a bad coil pack with only 1 cylendar misfiring (cylendar 5) replaced it and fixed the problem...
Need4Camaro is offline
Old 07-14-2020, 12:42 PM
Rhettwnorris's Avatar
Re: What are the symptoms of a bad coil on a 3.8L V6?
Originally Posted by Gripenfelter
Misfire cured!
Was a bad coil.
what size mm did you use to take coil pack off? I have a 96 Camaro 3.8 and I can’t find anything that works on it. If it’s an odd ball socket, will anything else work to remove it?
Rhettwnorris is offline
Naanz
V6 Tech
02-14-2016 11:11 AM
ad356
04-11-2015 11:12 PM
captcorvette
03-07-2015 12:37 PM
maybe2fast
02-05-2015 05:14 AM
GhostZ28
12-07-2014 11:53 PM
Quick Reply: What are the symptoms of a bad coil on a 3.8L V6?
