5 speed Camaro v6 making noises
Old 04-04-2011, 06:52 PM
JayBob34's Avatar
Can someone please help me. When the car idles it sounds fine. When I am on the throttle it sounds like a gatling gun. Was told that it could be the crank sensor, but open to advice... Thank you
JayBob34 is offline
Old 04-05-2011, 04:57 PM
DTRJAR's Avatar
Re: 5 speed Camaro v6 making noises
Fix it haha
DTRJAR is offline
Old 04-05-2011, 05:06 PM
JayBob34's Avatar
I just get my blazer and whoop your butt with it
JayBob34 is offline
Old 04-05-2011, 05:10 PM
DTRJAR's Avatar
how much you want to put on that just have to give me a week to put the motor in
DTRJAR is offline
Old 04-11-2011, 08:15 AM
rv93's Avatar
does it do this at high RPMs too? i had a friend whose 97 GTI did that, and i figured out it was the ridiculous timing advance at wot and low engine speed, causing the engine to knock like crazy. I got him to put some higher octane gas in, and the problem went away (the GTI has an old school distributor, so maybe a camaro wouldnt have the same problem). Still, its cheap and easy to try...
rv93 is offline
Old 04-17-2011, 03:58 PM
EineKatze's Avatar
Your crank position sensor is most likely not the culprit if there is no engine code being thrown, particularly while driving at high rpms. However, you may have a vaccume leak that is only taking affect while actually driving. I recently had a similar problem, however the leak had been there since I bought the car and never seemed to affect it before. I repaired the leak and replaced the PCV valve ($3) and the car runs worlds apart from what it did.
EineKatze is offline
NewsBot
12-21-2014 06:55 PM
ChrisFrez
11-30-2014 08:41 AM
siguy
11-27-2014 10:07 AM
07-04-2005 05:00 PM
Quick Reply: 5 speed Camaro v6 making noises
