Tower Strut Bar w/ ASR?
Old 01-11-2015, 11:37 AM
1996LT1Z28's Avatar
My son has a 96 Z28 with ASR. He wants to get a tower brace, but not sure if the ASR unit will get in the way.
Anyone install a strut tower bar with ASR?????
Thanks,
Mike
1996LT1Z28 is offline
Old 01-11-2015, 11:50 AM
Re: Tower Strut Bar w/ ASR?
The Spohn Performance shock tower brace works on all V8 models, 1993-2002, except the 96/97 SS.
http://www.spohn.net/shop/1993-1997-...wer-Brace.html
Injuneer is offline
Old 01-11-2015, 06:13 PM
1996LT1Z28's Avatar
Fred,
Thanks, I saw a couple of those on eBay and though I'd ask here before buying.
I'm going take a closer look on the car because the ASR unit looks awful close to where that bar will need to go across the engine.
Mike
Old 01-11-2015, 08:44 PM
Not Dave's Avatar
If you stand by the fender and look at the bolts you'd mount it to and go directly across the engine bay (draw a straight line) to the other bolts you'll see the ASR unit is further back than that, it won't interfere if the bar goes straight across. The Granatelli one and maybe some others I believe are a triangular shape may interfere as they attach to the firewall or just under the windshield.
I've looked at a lot of pics of 93-97 engine bays and very few cars have ASR and those that did only a handful had the brace and it shows plenty of clearance.
From what I've heard a beefier sway bar up front does more than that cross brace but you can't readily see it with the hood open. Cross braces are more for bling effect. I thought about getting one but will get better sway bars instead. I might eventually get a used one and have a buddy powder coat it white to match my car.
Not Dave is offline
Old 01-12-2015, 07:14 AM
Here's an LG Motorsports brace, on my Formula, without traction control. Might help you gage where it will fit. It passes over the valve cover centered between the first and second center-bolts:
Injuneer is offline
Old 01-14-2015, 08:09 AM
1996LT1Z28's Avatar
Thanks guys, I really appreciate the feedback!!
Looks like it won't be a problem at all.
IndyZman
10-22-2015 02:17 PM
WobblySausage
10-07-2015 02:44 PM
WobblySausage
10-07-2015 10:09 AM
football4life
10-04-2015 07:48 AM
92_RS_305
09-08-2015 07:47 PM
Quick Reply: Tower Strut Bar w/ ASR?
