sfc possible answer to problem? and advice needed
ok well i have a problem thats very scary at higher speeds, when i check my quarter times on my backyard dragstrip, my *** end feels like its floating left and right and its realy sketchy at 100+mph. also when i go over bumps and train crossings i hear a loud clunk from the drivers side rear. everythings tight and looks well under the car, but i noticed my very clean car is forming dents in the drivers side quarter panel. idk what the problem can be. i was thinkung maybe sub frame connecters would help fix this problem. what do u guys think?
also what ones are the easyest to install and will clear my exhaust. (i want 3 point sfc)
pacesetter lt, 3'' y pipe, borla adj catback.
umi tunnel brace adj torque arm, umi lca, umi panhard. qa1 fronts (lowered alot), qa1 rears (stock springs)
Re: sfc possible answer to problem? and advice needed
Side-to-side movement of the rear of the car is controlled by the panhard rod. Sounds like yours may need new buhings. The dents are not an unheard of problem with the Camaros, although I thought they were mainly on the pasenger side.
Ill check bushings after work. Idk how they can be bad cus there not even 2 months old... Could over greasing them whipe them out?
Awesome, thanks for considering UMI.
I usually tell customers it's a lot better to at least choose 2 pt than nothing. There is a bigger difference between zero SFC's and two point than there is 2 to 3.
Two points were the industry standard for many years and still work great!
ramey
ramey
Too much grease will not damage them, unless you've somehow found an unusual grease that is not compatible with the material the bushing is made out of - but that's not likely.
ramey
ramey
Did you replace the panhard rod bushings 2 months ago, or the complete panhard rod? Why type of bushings are they?
jim88iroc305
08-13-2002 09:24 PM
