V6 to V8 swap
Old Mar 25, 2003 | 04:33 PM
87_camaro's Avatar
V6 to V8 swap
has anybody ever swapped a 2.8 v6 with a small block 400?
will i have any problems with hood clearance because of the air filter? should i keep my electric fan or dump it and just go with the flex fan. Are there gonna be any problems fitting the tranny lines to the radiator? What do i have to do in order to change the fuel injection to carburetor? Are there any electrical problems i will run into?
I have a turbo350 tranny and it looks like the mounts will have to be changed to v8 mounts. Can i just throw on v8 camaro mounts or will i need a new kit with different brackets?
I've already heard that the headers will be the toughest part to fit in right. So i had a heads up with that part.
i can't really think of anything else to ask right now but if i'm missing something please tell me.
Danny
Old Mar 25, 2003 | 04:58 PM
Narsty91RS's Avatar
Make sure you replace the front springs or your front end will sag really bad.
Old Mar 25, 2003 | 11:09 PM
87_camaro's Avatar
oh!
really? damn that's gonna cost me more money.. hah oh well thanks for the advice.
is there anything else i should do?
Old Mar 26, 2003 | 07:38 AM
Jim85IROC's Avatar
If you can't afford the springs, forget about the WHOLE swap.
This is what I can think of off the top of my head that you'll need:
Motor & all accessories
transmission
motor mounts
throttle cable
springs
radiator
radiator hoses
fuel pick-up/pump from a carbed car
all new exhaust from manifolds to tail pipe (including cat)
With a real motor, you can also plan on upgrading to a posi rear, and adding subframe connectors.
That's all I can think of off the top of my head, but you'll be needing an endless supply of little crap too.
Old Mar 27, 2003 | 03:09 AM
87_camaro's Avatar
yeah
yeah i know about all that stuff... it just keeps on growing too. that list you gave me, i already know and have most.
i guess really it's just the electrical stuff that i am worried about.
the springs was good tho. thanks for that
Danny
David Dempsey
Mar 12, 2016 12:42 AM
blac94Z
Nov 4, 2015 01:59 PM
gonzo275rltw
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
