Car Noises (WTF!)
Old Mar 22, 2003 | 07:26 PM
tainted's Avatar
Car Noises (WTF!)
Ok. Wtf.
I'm going about 90 when I have to break kinda hard, nothing too crazy, when after I pull out of the turn, my car starts making a rubbing noise. Also, my car makes this engine whine(sounds like a whine of a supercharger, its that loud) noise on a stock ls1 engine (00 SS).
One more thing, my car makes this funny noise when I start my car. It goes away after a few minutes (and either stops when I rev my engine or is blocked by my engine noise).
Note, when my RPM's get higher, that whiney noise gets louder.
Someone help me :>
Is the rubbing noise (sounds a lot like pipes or somethin) my suspension?
Help me out guys, thanks a lot.
Old Mar 22, 2003 | 09:50 PM
Camaro ChriSS's Avatar
hmm. Do you have any mods (I know you say stock, but just double checking)? The noise at start up - is it a whine or a ticking? Is the whine constant when driving (could be an air leak around the air box)? If you can answer these questions, we can determine a little more.
Old Mar 22, 2003 | 09:54 PM
73307's Avatar
If you have cut outs those could be rubbing.
Old Mar 22, 2003 | 09:58 PM
stik6shift98's Avatar
most likely piston slap......
Old Mar 22, 2003 | 10:08 PM
99blackSS's Avatar
I disagree, his car clearly grew a supercharger.
Old Mar 22, 2003 | 10:10 PM
oh stupid me.....i should water my ls1 so that it grows a supercharger too
Old Mar 22, 2003 | 11:26 PM
ZIPPERR's Avatar
Re: Car Noises (WTF!)
My guess is your alternator is going out. ..
Old Mar 22, 2003 | 11:30 PM
JoshuaH82's Avatar
The noise when you first start the car is most likely one of the pumps (water or fuel, can't remember which) priming up. Mine does the same thing. It goes away after a little while. I had a chirping noise a while back and replaced my belts. Took care of that problem. I wasn't aware that the 2000s had piston slap issues.
Old Mar 23, 2003 | 12:12 AM
tainted's Avatar
Wink
My car is COMPLETELY stock. It's not a whine, the whine happends, again, usually after hard stops and sharp turns. The noise at start up is...mmmmmm...I guess more of a ticking, not a whine. My car grew a supercharger? Sweet! ;D
As far as anything going out, I highly doubt it. I got my ss from a dealer, and it was GM certified passing a 100 pt inspection. I got a 3 yr warranty (this is why it's still stock), so whatever you think the problem could be, tell me and i'll tell the dealer to check it out.
Thanks for all the help boys
Old Mar 23, 2003 | 12:21 AM
ZIPPERR's Avatar
Well, I reason I say it could be you alternator is because on my sister caddy she was getting a whine. It turn out the alternator bearings were shot causing it to whine..
GM 100 pt. inspection>
^they use that mainly as a selling pitch..
Old Mar 23, 2003 | 09:36 AM
nikkev's Avatar
The noise that comes and goes is your A.I.R. pump.The whine that changes with RPM's is possibly the alt.That's what it sounds like to me.Why not take it in and have it looked at if it's still under warranty?
Old Mar 23, 2003 | 10:45 AM
#7's Avatar
I'm w/ Zipper and nikkev, I had the whine associated w/ motor reving...Larnach clued me to it alittle while back and it was the Alternater. You can try the "Mechaics stethascope" a 2ft. piece of broom stik,or your breaker bar hold on end to the part in question(making noise) the other end in/on your ear will help you isolate the sound...you'll hear it thru stik or breaker bar or something like those.
That sound at start up I have that one too...other than the normal sound of the air pump operating for a few min.s every once in awhile mine kinda gets loud like War war war war whar whar and does stop if you give it gas but returns at idle.Havent quite figured this one out(not fixed) and the sound isnt everytime its a rogue sound(driver side).But the air pump at start up is heard faintly this is normal but I think my rogue sound is a sign that its goin bad
Old Mar 23, 2003 | 11:00 AM
99blackSS's Avatar
I don't know about that noise when braking after 90 but this one sounds like piston slap. I would just take the car to the dealer and let them deal with it. Might want to record how many miles were on your car when you dropped it off at the dealer.
Old Mar 24, 2003 | 12:16 AM
fbird95's Avatar
I'm with the alternator, but mine went out all the way and it sounded real whinny like no super charger i've heard lately. Consider your self lucky if you get a little bit of time between the time the alternator goes and the time it takes to go get a new one. This way you can bolt it in there as soon as you have time.
Old Mar 24, 2003 | 12:29 AM
Re: Re: Car Noises (WTF!)
yup piston slap is what i have suggested earlier and that is most likely what it is.....and hes right about writing down your miles
jj71787
Dec 30, 2014 02:15 PM
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
Christopher
Sep 14, 2002 03:08 AM
