Is my lid on wrong?
Old Mar 21, 2003 | 06:33 PM
JBH's Avatar
JBH
Is my lid on wrong?
I just replaced my air filter for the first time. I just bought the car. I installed a Fram filter and when I got the lid back on everthing seems to be correct, the lid fits up to the mass air correctly all the clips are in place and the clamps are latched but you can see the rim of the filter through the back of the lid. It appears that the lid is flush against the filter and the filter is flush against the bottom of the airbox but it just doesn't look right. It is a SLP lid. Here is a pic
Lid
Old Mar 21, 2003 | 07:00 PM
73307's Avatar
Just try and see if you can push that back a little it might not be locked all the way.
Old Mar 21, 2003 | 07:59 PM
JBH's Avatar
JBH
I just went out and checked it. The back corners of the sides are resting snug on the back of the fan shroud that the air box sits on. The MAF and bellows are all lined up correctly also.
Old Mar 21, 2003 | 08:51 PM
one wicked element's Avatar
The front of the lid needs to be pushed back past the air box. It doesn't sit even the lid, but behind the lip. Try to undo the lid and put the end tabs (ie. what is shown in your pic) like in at a 45* angle, and then bring down the front and lock it.
See if that helps.
Milo
Old Mar 21, 2003 | 09:07 PM
psychocabbage's Avatar
yeah.. it doesnt look like its pushed all the way back to me.. undo the clips as mentioned above, make sure all tabs are in their hangers and push towards the back, they should slide a tad bit more, then bring it down and clasp it.
Old Mar 21, 2003 | 11:27 PM
JBH's Avatar
JBH
I think my problem was the smooth bellows. I put the standard one back on and it let me move the lid back. The clips snapped down more firmly and the tabs are all the way against the holes. The lid seems to be matched up to the box better. If you get down and look closely you can still see the rim of the filter but the way the filter sits on top of the inner tray and the way the back of the lid is flat across the back I don't see how you would not be able to see the lip of the filter. I will take another pic in the morning and see what you guys think. Since the previous owner had it sitting on top of the airbox wrong I hope there hasn't been a bunch of junk sucked into the motor.
Old Mar 22, 2003 | 12:14 AM
Camaro ChriSS's Avatar
Fitment can be a SLIGHT bit of a problem with aftermarket lids. Its not uncommon to have a little of the gasket showing.
Make sure the front clips are going on without any heavy force needed to ensure that it is seating properly. You may find it impossible to get the four tabs at the back to fit in precisely, FWIW.
Old Mar 22, 2003 | 04:14 AM
02 Blue Z's Avatar
I have the same thing on my slp lid tried everything to get it to seal no luck.
took newspaper and made a small fire the fire and smoke would get sucked in on the side and back of the lid above the filter called slp they are going to take a look at my lild. the prob is the back of the neck on the lid hits the base of the filter housing. will not let the lid set down tight to the base on the back side.
who else has this prob.
Old Mar 22, 2003 | 07:47 AM
JBH's Avatar
JBH
02 Blue-That could be part of my problem. I can see on the neck of the lid and on the fan shroud behind the airbox where the 2 pcs rub together.
Aaront810
Aug 29, 2020 09:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
Aaront810
Sep 11, 2015 11:24 AM
