What clutch are you using with n2o set-up?
Old Mar 21, 2003 | 10:23 AM
john97z28's Avatar
My stock clutch is fried, I need a new one. Any suggestions???
Old Mar 21, 2003 | 04:43 PM
HungryT/A's Avatar
That's a good question. I'm looking for an answer, too.
Some would say get the SLP kit, some swear by the SPEC and there are the folks who say pay more now, never have problems later=> Street Twin.
If they don't stop me, I'll get the twin for sure.
Old Mar 21, 2003 | 05:56 PM
95greendragon's Avatar
I think the street twin is overkill, but I am leaning towards a spec II or III. I have heard bad things about all of them. I have personal exp. with a centerforce df on my supercharged 3rd gen. I loved it but I hear bad things about them on 4th gens.
Old Mar 21, 2003 | 08:36 PM
stik6shift93's Avatar
I've heard of the slp failing under big shots, if you're gonna keep the 150 I'd go spec stage 3. That's what i'm running, no problems with it so far.
Old Mar 21, 2003 | 10:53 PM
JSK333's Avatar
I have a Street Twin. The only slipping I get is from my drag radials.
Old Mar 22, 2003 | 12:27 AM
jakef2003's Avatar
Chalk another one up to the Street Twin.
Old Mar 22, 2003 | 01:59 AM
stik6shift98's Avatar
yup i have the spec 3 ceramic and love it
defintly go with that one and i will be satisfied
Old Mar 22, 2003 | 03:02 PM
93m6's Avatar
in the sig
Old Mar 22, 2003 | 05:42 PM
Tweaked Zed's Avatar
Spec IV disc with a Centerforce press plate....just cause I had it from the useless DF. Stripped all the material off the one side of the CF, which ended up to be only stock friction material anyway.
IMHO if I were to do it on a streetcar with N2O, I'd just use the stock press plate and a new Spec III disc (6 pucks now instead of the old 4). They're all the same Valeo press plates until you get a Street Twin, then they're modified a little bit.
Old Mar 23, 2003 | 01:22 PM
john97z28's Avatar
Thanks guys, now I just have to decide on the SPEC or Mcleod..$$# being the issue.
Old Mar 23, 2003 | 02:05 PM
InjectedSS's Avatar
Im using a centerforce dual friction clutch that i got brand new FOR FREE and thats the only reason i went with it cause its WAY to expensive and i know some people say their JUNK BUT I actually installed mine the right way so i dunno WTF other people are talking about! ive made numersous 10 sec passes down the track running ET DRAGS launching at 5500rpms and spraying a 50 shot outa the hole and that clutch is loving every minute of it on the other hand if id paid for one i would have gone with a spec stage 3 cause ive heard nothing but good from those clutches
Old Mar 24, 2003 | 12:15 AM
howd u get it for free??
i would of sold it and bought myself a spaec 3 ceramic
Old Mar 24, 2003 | 07:27 PM
gb95zconv's Avatar
After frying a clutchnet kevlar disc I went to the SPEC 3 carbon.....it was holding up to the 150 shot fine . When I pulled the motor to do the 383 it showed very little wear. It took alittle getting use to because it engages higher and harder than the stocker, but it will hold .
Old Mar 27, 2003 | 09:30 PM
11sec's Avatar
my star stage 3 ceramic has held in the 1.5's with 100 shot and bolt ons.
Old Mar 27, 2003 | 09:34 PM
rskrause's Avatar
If you can afford it, get the Street Twin. Think about this: did you ever see anything negative posted about this clutch (except about the price)?
Rich Krause
