replace fuel pump?
Old Mar 17, 2003 | 10:35 PM
blackhawk96's Avatar
replace fuel pump?
my fuel pump is unusually loud, i've even had a couple of other f-body owners comment on it....has anyone else had this "problem" on their car, and if so does that mean the pump needs replacing?
Old Mar 17, 2003 | 11:33 PM
chesee48's Avatar
Does your car have a hard time cranking over when starting? thats a good sign that the pump is going or gone too...
Old Mar 18, 2003 | 11:08 AM
actually it does a lot of the time. sometimes when it's been sitting for a long time it will turn over right away, or if i turn it off and turn it back on it will turn over quickly. but most of the time it takes it a few seconds to turn over....i even try turning it to on to let the fuel pump run for a couple seconds but that doesn't seem to help....so i guess it sounds like i need a new one.....where's the best place to get one and how much do they usually go for? thanks for the help.
Old Mar 18, 2003 | 01:00 PM
LT1speed's Avatar
I just replaced the pump last week. If you buy the pump assembly for the year model it comes complete and is very expensive. Some have bought the walbro pump. I bought a pump for a 92 camaro 350 tpi. The pump was about 75 or 80 bucks. Worked great. I needed a quick fix because the car was down.
Old Mar 18, 2003 | 10:15 PM
chesee48's Avatar
Yep, exactly how my car was. Its your fuel pump.
How many miles u have on the car BTW?
Old Mar 19, 2003 | 09:22 AM
it's got about 87xxx miles.....how many did yours have when it went bad?
Old Mar 20, 2003 | 02:38 AM
chesee48's Avatar
I had the same exact miles. High 80's when i changed it.
Just stuff that has to be done sooner or later i guess
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
