Problems finding a mounting point for my solenoids and WOT switch.
Old Mar 16, 2003 | 05:55 PM
ExMustangOwner's Avatar
Question Problems finding a mounting point for my solenoids and WOT switch.
Any one help me mount my fuel + nitrous solenoids, and WOT switch? I have a 2001 LS1 with a Strut tower brace. I hear that helps. Thank you all so much
Old Mar 17, 2003 | 09:00 AM
stik6shift98's Avatar
mount your solenoids on the drivers side...way in front....and the wot switch goes behind the throttle body so that the little needle is directly behind the part the throttle stop thing hits when it is wide open
Old Mar 17, 2003 | 10:17 AM
Mikael's Avatar
http://66.43.184.45/hidden.htm
I put the solenoids on either side of the intake under the air silencer, and the WOT switch inside the car hose clamped to the steering shaft. Very hidden, and easy to do.
Old Mar 17, 2003 | 07:47 PM
i hope no one ever takes your lid off...then its not sooooo hidden
Old Mar 18, 2003 | 10:34 AM
What bolts, nuts come with the kit? Anyone have any pictures? I bought a used kit and just have the solenoids and brackets. Do I do any drilling? I don't care if it's hidden or not.
Old Mar 18, 2003 | 04:58 PM
yes u will most likely do some drilling to keep the solenoids in place
Old Mar 19, 2003 | 01:51 PM
Ok that's what I was wondering. Any more pictures or last minute mounting points? Thanks again. Weather pending, I'll probably do the install this weekend.
Old Mar 20, 2003 | 07:25 AM
Zippity'Z's Avatar
The WOT switch goes on the throttle body to activate when it's at wide-open throttle. You can see some pics of them mounted on this page http:/www.jimmy-jams.com/activationswitch.htm
*R
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
Timberwolf
Jul 20, 2002 08:45 AM
