How do you wire a window switch on an LT1?
Old Mar 13, 2003 | 06:57 PM
craigffb's Avatar
Anyone know how to wire an MSD widow switch up on an LT1?
Thanks,
Old Mar 14, 2003 | 09:50 AM
BAD 97 WS-6's Avatar
Red Wire---Power...run it to a fuse, like the ignition fuse.
Black Wire---Ground....
Yellow Wire---Goes to ground wire from nitrous relay
White Wire---Goes to tach output....(green wire that goes to the connector that plugs into your coil
Old Mar 14, 2003 | 10:40 AM
craigffb's Avatar
That seems pretty easy. Thanks.
Old Mar 14, 2003 | 01:37 PM
craigffb's Avatar
No green wire. I have a PINK, PINK w/BLACK, and YELLOW w/BLACK. It's a 94 LT1 wth an Accel 300+ box, can anyone help?
Thanks,
Old Mar 14, 2003 | 05:55 PM
craigffb's Avatar
I think I found my own answer. The 300+ has a tach lead on the harness so I would guess I can use that to connect to the white wire on the window switch right??
Old Mar 14, 2003 | 08:37 PM
exactomundo
The Seer
Nov 20, 2014 06:32 AM
Rich_z28
Aug 29, 2002 10:44 PM
Rich_z28
Aug 27, 2002 12:20 AM
x7x7
Aug 15, 2002 06:49 PM
