n20 pressure gauge
Old Mar 12, 2003 | 02:46 PM
OffspringZ28's Avatar
n20 pressure gauge
How many of you have a mech nitrous pressure gauge installed in your a-pillar? if so, how should i go about installing this? any tips/tricks you guys can offer me?
Old Mar 12, 2003 | 04:37 PM
sniffin94's Avatar
its not hard. The only problem will be getting the gauge to sit flush in the pod. To do this I suggest you cut one of the U brackets that comes with the gauge and attach it to the side where the line comes in. Then you can just tighten the nut to get it to sit flush. Everything else is pretty easy. Let me know if you need anymore help, oh too bad I just left ft lauderdale or I could help you
Old Mar 14, 2003 | 05:57 PM
craigffb's Avatar
How long of a line did you guys run and where did you run it?
Old Mar 16, 2003 | 03:16 PM
sniffin94's Avatar
I ran a 12' line from the bottle to the a-pillar. You need about 8' to go from the solenoid
Old Mar 17, 2003 | 09:04 AM
stik6shift98's Avatar
yup 8 feet sounds about right....from solenoids
Dec 1, 2016 05:37 PM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
surreybrad
Apr 22, 2015 06:40 AM
ad356
Apr 11, 2015 11:12 PM
Z28countrymama
Jan 22, 2015 02:50 AM
