10:1 Compression ? Detonation ?
Old Mar 4, 2003 | 02:35 PM
CODY BEHNKE's Avatar
Anyone having any problems running this CR on an L98?
Old Mar 5, 2003 | 01:17 AM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Its fine if you have aluminum heads, and not recommended with iron heads.
Old Mar 5, 2003 | 07:04 AM
Jim85IROC's Avatar
I have it with 461 iron heads, which don't exactly have the most modern combustion chambers. Even with an agressive PROM code I get very few knock counts, and I know precisely where they are coming from. Once I trim back that section of code, I expect that I may be able to advance my timing another 2* without excessive knock counts.
Old Mar 6, 2003 | 04:24 PM
Z28SORR's Avatar
This question is meaningless as writen. You can run very high ratios without detonation or have it in a low compression engine.
But I think we all know what your getting at.
And you sould not have a problem.
Kevin91Z, Please inlighten me;
. Not recommended by whom???
Jim85IROC, Like your car.
Old Mar 7, 2003 | 12:32 AM
PLANT PROTECTION's Avatar
Im running 10.6:1 with an ARAP spark table with aluminum heads and it has not knocked once. Remember, your cam has something to do with it also.
Old Mar 7, 2003 | 07:49 AM
Jim85IROC's Avatar
Thanks.
Old Mar 7, 2003 | 09:31 AM
Kevin91Z's Avatar
Not recommended by common knowledge. Or so I thought...
Old Mar 7, 2003 | 03:09 PM
Z28SORR's Avatar
Kevin91Z,
Not trying to be a smartass here, just see a lot of stuff that doesn't always make sense to me.
Been around Hot Rods and racing since before I could drive, legally, and that was 1963. Back then there weren't to many people that could afford aluminum heads and many of those cars had 11, 12 and even 13:1 compression ratio's.
Anyway, it's all in the search for knowledge.
Old Mar 7, 2003 | 10:06 PM
aklim's Avatar
I am running 10.8 with AFR 190cc heads and 93 octane with a modified ERPOM
Old Mar 7, 2003 | 11:53 PM
Kevin91Z's Avatar
40 years ago you had leaded gas and higher octane, so compression ratios that high were easy to support. Nowadays you're lucky to get anything above 91 octane. Those of you with 93 octane are special. My car pings at WOT using 91 octane with 10.3:1 compression on Corvette heads, and only 30 degrees timing. I have to use 100 octane unleaded at the track.
Old Mar 8, 2003 | 12:56 AM
stonedchihuahua's Avatar
Timing, cam, shape of parts in you combustion chamber, EVERything has to do with it.
I konw a guy who runs 12:1 on his old boss 302 (true boss) and he can run it on regular without any sign of detonation. He also turned back his timing a bit
Old Mar 8, 2003 | 01:48 AM
Chris Ja's Avatar
Eternal Member
Smile
You have to watch what cam is used. I had a 214/465 with no knock. I went to a 219/525 and got some knock at WOT. I had to burn another chip and adjust the timing.
The old engines had leaded gas with the high compression to help with spark knock. I have had at least 20 muscle cars from back then and I tried unleaded reg one time when it first came out. The engine knocked so bad I though it would blow up. When you turned the engine off it ran on for 15 to 20 seconds. I have never tried it again and that has been since 1972.
Quickss96
Jan 29, 2016 05:56 PM
surreybrad
Sep 29, 2015 09:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
13qtr
Jul 19, 2015 05:30 PM
stwrt83
Sep 12, 2002 12:39 PM
