Rack and Pinion....
Old Feb 18, 2003 | 11:17 PM
sleeperZragtop's Avatar
Rack and Pinion....
...another question...I'm in the middle of removing my upper and lower a-arms and I'm having issue's removing the bolt at the rack and pinion...the rack is blocking the removal of that bolt..therefore hindering Shawn R. of getting his lowers ...is there the only two bolts holding the rack in place at the k-member...I just need to move it a half an inch..thanks alot..
Mike
Old Feb 18, 2003 | 11:36 PM
97TA-WS6-Con's Avatar
Hmmm. I know the problem. You cannot remove the last bolt on the A-Arm because it will not clear the inner tie rod end.
It seems to me that there was two bolts that secured the rack and pinion. That was it. I then just pulled the rack out a little.
I'll check now and also the Haynes
Old Feb 18, 2003 | 11:39 PM
Yeah I just see the two bolts that secure the steering. Have you removed those?
Old Feb 19, 2003 | 02:22 AM
I did..she's still a little tight, maybe I'll have to disconnect the steering shaft ...I'll give it another go in the morning..
Old Feb 19, 2003 | 11:51 AM
tap it gently with a hammer to see if it needs to break loose.
Old Feb 19, 2003 | 12:17 PM
Dumb *** question...
..what if I turn the steering wheel...will the rack ends move to the side?
Victor Lamb
Aug 26, 2017 02:52 PM
97blackformula
Aug 27, 2015 06:02 PM
Boss002
Jul 24, 2015 10:47 AM
Boss002
Jul 9, 2015 03:33 PM
windnsea00
Feb 19, 2003 02:05 AM
