Anyone know the rearend width???
Old Feb 12, 2003 | 11:32 PM
stonedchihuahua's Avatar
Anyone know the rearend width on my 85 camaro 10 bolt... drum brakes... if it matters.. I wanna put in a 9 inch but I need to know the size
Old Feb 13, 2003 | 08:35 PM
Stephen 87 IROC's Avatar
All third gens are the same width. Roughly from the end of the axle to the end of the axle is 63" +/- 1/2". That's the surface that the drum/wheel will mount on. Changing that width will require different offset wheels.
Most factory 9" housing are too wide but there are a few models that work well. I used one from a 1970 F100. The only bad thing about it is that both axles were the same length. That put the pinion over to the passenger side 2". A proper car diff will have the pinion in the center and the driver side axle will be shorter than the passenger side.
I installed mine with ladder bars so I didn't have to worry about finding some way to attach the torque arm.
Old Feb 14, 2003 | 01:02 AM
well what I am planning on using for the touque arm mount is I'm going to make a steel bracket
mrwz28
Jul 8, 2015 09:11 PM
Flint78
Jun 21, 2015 01:28 PM
ddr698
Jan 9, 2015 10:05 AM
Speeds8erM-1
Classic Engine Tech
Aug 21, 2002 01:06 PM
kurshinsky
Jul 13, 2002 12:32 PM
