Are stock Snorkles on TPI's restrictive???
Old Feb 12, 2003 | 08:00 PM
BlowBye's Avatar
Engine is a bit modified and for some reason im under the impression that the stock intake snorkel is restricting any air.
This is the current setup
http://pic3.picturetrail.com/VOL11/8...4/18975653.jpg
But id like to do this
http://exit3.i-55.com/~davidlt/air_top2.jpg
As for the stock snorkel, its basically been gutted at bottom, but i think its still restrictive(Dont ask why) Would i see an increase with the second pic? I dont care for look, but just would like to get as much air into the engine as possible.
Old Feb 12, 2003 | 08:27 PM
1fastformula's Avatar
Thumbs up
First thing is that you have a Camaro and the setup you wanna go to is for the Firebird. Your stock snorkel is WAYYYY better than the stock Bird setup. Depending on your year model, you can do away with the snorkel and mount a K&N straight to your throttle body. 91-92 models are the only ones you can do that with. Check out my website and look at the second page, there you will see my snorkel setup. If I were you I would stay with what you have because fresh air is getting in alot better through a straight pipe than a bent one
Later
Old Feb 12, 2003 | 08:50 PM
BlowBye's Avatar
Sticking a K&N directly to the TB is a bad idea, Its sucking in hot air. As for the Stock snorkel, I do have K&N's. Reason i was thinking its restrictive is how thin it is at the very end.
Old Feb 12, 2003 | 08:54 PM
CODY BEHNKE's Avatar
It flows very good and the only thing that is really better is the SLP CAI
Old Feb 12, 2003 | 09:37 PM
kandied91z's Avatar
how much power are you pushing....if the box is gutted and your airway is free (no debris, foglights, etc.) then it's more than enough for the stock setup.
a filter straight to the tb is a bad idea since like you said your sucking up hot air. so is the one in the other pic since essentially it isn't that much "cooler"
check out mine as another idea, it works really well and i don't see any amount of power you might run needing more than the 4" it has.
camaroguy50613
May 27, 2016 09:00 AM
canbaufo
May 25, 2015 12:01 PM
mritter1965
Exhaust System
Feb 15, 2015 07:31 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
4586
Dec 6, 2014 05:20 PM
