Cooling issues
Old Feb 12, 2003 | 07:04 PM
86 redbird's Avatar
Cooling issues
I have a stock 305 lg4 86 ta. I'm about to jerk the 305 and put in a 383. My questions is, will there be any cooling issues with the stock fan? The 305 always ran at about 200 on the open road and about 220 at idle. This was also after a 160 thermostat.
I want to keep the temps down on my new motor. Any advice?
Old Feb 13, 2003 | 03:48 PM
STL REVLIMIT's Avatar
wtf? you car runs at 200 on the open road and thats with the 160 thermostat? O_o thats pretty crazy. My car on the open road runs at around 160 and whats with the fan off. Then in traffic or at idle it runs at about 180. I think your thermostat, water pump, or even just your radiator cap is bad. My car used to run at around 200+ also but I found my radiator cap was bad. Changed it and the temps dropped down to around 180 or less. You should check on those parts.
Old Feb 14, 2003 | 01:57 AM
86 redbird's Avatar
i was under the impression that all 3rd gen cars ran at 220 durring idle.
or at least teh carburetored cars
Old Feb 14, 2003 | 04:10 AM
well I also have a 160 degree thermostat and also a fan switch.
Old Feb 14, 2003 | 09:10 PM
86 redbird's Avatar
I have the 160 thermostat also, but the fan doesn't come on until 220. It is just a single fan, not the dual fans that came on the tpi cars.
Old Feb 14, 2003 | 09:28 PM
jeffsbluez's Avatar
You need to change the fan switch to an aftermarket piece. You could also disconnect the A/C at the pump and turn the air controls to defrost. That should turn the fan on all the time the cheap way.
Old Feb 14, 2003 | 09:35 PM
yea the fan switch would help a whole lot. Another way you could do it is just hook up a switch which sends a ground the fan switch on the side of the motor. Thats how I did it O_o
Old Feb 15, 2003 | 04:37 PM
86 redbird's Avatar
Fan Switch? I'm assuming it is a switch that turns your fan on, but where can i find it? How much am I looking at for it?
Old Feb 15, 2003 | 06:38 PM
jeffsbluez's Avatar
It is a sensor that screws into the side of a heads. You should be able to get one from any performance parts dealer. Check out the summit or jegs catalog. I'm don't think it would cost more than $80.00 .
Old Feb 15, 2003 | 06:53 PM
RANGER'sIROC's Avatar
I have an 86 w/305 TPI and only a single fan. Down the road it hits maybe 180. At idle it does go up to 220 but the fan kicks on. The thing with the switch. If you are cheap like me you can buy a generic toggle switch and mount it under the dash. I put mine in the Diag. Check housing. You will have to run a wire(ground) to the ground after the fan relay switch. If I see my temp. going up I hit the fan. I also don't have a/c. Good luck and don't pay the $80 you can use that elsewhere. Later Ryan
Old Feb 16, 2003 | 12:06 AM
90rocz's Avatar
Two things to avoid; 1= Don't run too much timing advance, 2= don't run lean, these will help a lot.
Some fixes are;
1)...low temp fan switch, which I believe screws in the front of the intake or block somewhere. It'll turn the fans on at about 195* and off around 180*.
2)...160* t-stat, which will allow water to circulate to the radiator sooner and slow it from taking on so much heat.
3)...the "over-looked"Radiator-cap, failure to pressurize will let it boil at a lower temperature.
calaban
May 18, 2020 06:43 PM
timmy39120
May 8, 2015 11:41 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
MattFick
Feb 15, 2015 10:16 PM
