Konig Monsoon owners, stripped my key
Old Feb 12, 2003 | 06:43 PM
Dave 96TA's Avatar
Anyone done this before? Being careful not to get the tire iron too deep and scratch the wheels, I guess I didnt insert the key 100% and when I turned it hard (the lug was already snugged) the inside of the key stripped bad enough to make it useless. I use a long 12mm shaft to do the non-keyed nuts so those arent a concern. How can I get a replacement key?
Old Feb 12, 2003 | 09:20 PM
stik6shift93's Avatar
Go to a local tire store that carries konig and they can order you one.
Old Feb 12, 2003 | 11:40 PM
Z28ROC's Avatar
You'll probably have to buy a new set of 4 lugnuts with a key. From Gorrilla or Coyote (I think that's it).
I know what you mean about the shoulder of the key hitting the outer edge of the lugnut hole and scratching it. I ground that part down on my bench grinder. Tapered it, so it would not contact anymore.
Old Feb 13, 2003 | 05:21 PM
Dave 96TA's Avatar
Guess I should get a new one and do that. Had to do it to a spark plug socket to get the #8 plug in/out safely...
Magenta_Hearts
Mar 25, 2015 10:24 AM
Caps94ZODG
Sep 7, 2002 10:09 PM
Eric H
Aug 10, 2002 06:39 AM
Brian-94TA
Jul 31, 2002 02:52 PM
