nitrous windows ????
Old Feb 4, 2003 | 11:00 PM
hitman8728's Avatar
Cool nitrous windows ????
hey guys i just ordered my nx kit and a msd window i have a ? abou the window i was wondering if i shoul dhave it turn off befor my car shifts(i have an auto) or let it go through? no if i have it shut off befor it shifts will it make the tirs spin when it comes back on? and will it harm my rear end? also i was wonder what u auto guys pills you use for the msd window thfor forr all your help.
Old Feb 5, 2003 | 12:18 AM
GhostZ's Avatar
Depends on how long you want your tranny to last you. 4L60E have a tendency to go down the tubes > 400 ft. lbs so you're asking for a rebuild if you spray through the gears.
Some people spray right through some people have it shut off a couple hundred RPM's before their shift. Completely up to you.
How big of a shot do you plan on running? You shouldn't spin after the shift since you're still putting your normal NA power to the ground during the shift....and I doubt you're going to be spraying a 200-300 shot.
Shouldn't harm your rear end.....unless you decide to spray from the hole with slicks. Then you're taking a chance. The great thing about auto's is we can preload the rear a bit by braking and bringing up the RPM's. Makes your launch less strenuous on the rear end.
Old Feb 5, 2003 | 12:20 AM
hitman8728's Avatar
all im goign to do is a 75shot and at the track maybe 100 but prob 75 the hole time
Old Feb 5, 2003 | 12:24 AM
GhostZ's Avatar
You should be fine but you may want to limit the times you spray through shifts.
The clutches in my tranny are already shot so I'm going to a built TH400....my last dyno before headers, cam and rr's was at 376tq so I knew I have been pushing my luck on how long this transmission is going to last before a rebuild.
Go easy on it if you don't have the means to do a rebuild...but like I said, I wouldn't worry to much with that small of a shot.
Old Feb 5, 2003 | 08:32 AM
hitman8728's Avatar
well will it be a lot safer to stop it when the car shifts i already bought the windo for it so it not a big deal i just didnt want the tirs to spin every time i shift
Old Feb 5, 2003 | 08:38 AM
RacinLT1's Avatar
It'll be tough to spin the tires with a 75 shot when shutting off for the gear change.I would recommend shutting it off when the car shifts.
I spray through shifts with a 4l60e,got about 5 months out of a 100% stock trans.
I had the 4l60e built,and went a season and it still shows no signs of wear. The trans is coming out and getting replaced with a th400,mainly cause the new combo will destroy the 4 spd.
Old Feb 5, 2003 | 08:56 AM
hitman8728's Avatar
k cool and last thing when should i make my nitrous come one do u think about 3,000 that sound good?
Quickss96
Jan 29, 2016 05:56 PM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
95blkss
Sep 22, 2015 03:18 PM
z28cam1993
Sep 9, 2015 04:08 AM
