Please help i need a set up
Old Jul 28, 2010 | 05:52 PM
Bean66's Avatar
i have a 99 ls1 street rod 373 detroit tru trace rear end. long tube headers and programer and 130000miles on motor i would like to pull it and re do it what should i put in to the motor i have a 1500 budget
Old Jul 29, 2010 | 07:14 AM
Kraest's Avatar
Retired
A re-ring with an aftermarket cam swap and a used LS6 intake manifold.
Old Jul 30, 2010 | 07:49 AM
AL SS590 M6's Avatar
I would change out the rod bearings, check the main bearings, and mic the crank too. Then put it back together with a new oil pump, hardened pushrods, new valve springs, and new GM replacement lifters.
Old Jul 30, 2010 | 10:14 AM
Bean66's Avatar
what size cam would be a good set up. it is a six speed with a/c . and do i need to change the springs on the head with a cam swap
Old Jul 30, 2010 | 10:16 AM
Bean66's Avatar
where can i get a cheep ls6 intake. and does anyone know where up can get cheep ls1 parts
Old Aug 2, 2010 | 07:12 AM
Kraest's Avatar
Retired
The Futral Motorsports F13 is a great cam. You need to change the springs, oil pump, timing chain set, springs, and pushrods on a cam-swap. Most aftermarket cam kits come with everything you need. With 130k miles, I'd also change the lifters like Al said.
You can find a used LS6 intake manifold here on the internet. Welcome.
HectorM52
Jul 30, 2017 11:46 AM
z28leno
Mar 12, 2015 07:42 AM
FredM
Mar 6, 2015 03:04 PM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
Jan 23, 2015 01:13 PM
