Quick Question???
Old Feb 2, 2003 | 09:55 AM
qwick_trip's Avatar
Question Quick Question???
Ok I GOT A QUESTION. I AM PUTTING ABOUT $4,000 IN MY CAR THIS WINTER AND WILL PROBABLY BEI N THE 11'S. BUT I NEED TO KNOW I HAVE A 6 SPEED TRANS AT THE DRAD STRIP DO I NEED A TRANS BLANKET OR A SHIELD?
Old Feb 2, 2003 | 10:44 AM
TedH's Avatar
From my understanding, a stock transmission with stock frame and floorboards, does not need a transmission shield or blanket. I would definitely obtain a copy of the NHRA and/or IHRA rulebooks before spending all of your money. In NHRA the ET break for a rollbar is 11.99, in IHRA it is 11.49. You will need a driveshaft loop as well.
I have a transmission blanket on mine after it exploded last fall. I learned my lesson. Even though it is not required at my ET I was very "lucky" not to lose my foot.
I also installed a six point welded bar long before I hit 11's. I just don't want a problem if some dragster comes up my butt at the big end of the track or I get a flat tire or hit a seagull or something. Also, the welded bar stiffened the car up quite a bit so I didn't have to install subframe connectors.
Be smart and be safe. Have fun modifying your vehicle.
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
Jan 23, 2015 01:13 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
