where to buy lower contorl arm?
Old Jul 14, 2010 | 09:35 AM
lovemyblackz28's Avatar
Called the dealer for lower contorl arm bushing and they dont have any. Where can I order from? Any suggestions?
Old Jul 14, 2010 | 10:37 AM
JohnD's Avatar
Any reputable parts house should have them, try NAPA.
Old Jul 14, 2010 | 11:09 AM
koolaid_kid's Avatar
The aftermarket bushings are readily available.
Here is an example: http://www.summitracing.com/parts/MOG-K6178/
Old Jul 14, 2010 | 12:23 PM
Front suspension or rear suspension lower control arm?
Old Jul 14, 2010 | 12:38 PM
Front.
Old Jul 14, 2010 | 09:50 PM
ES makes a poly set for the front. The lower bushing set has a revised design for the vertical bushing that eliminates the bind that often accompanies rigid poly bushings, using a spherical poly surface. I've had the ES fronts in the car for about 12 years now, upper and lower, and no problems. Nice solid feel to the front end.
Old Jul 14, 2010 | 10:16 PM
do ya have a link for this?
Old Jul 15, 2010 | 05:18 AM
I bought the ES Hyperflex Master Kit for the 4th Gen from Pace Performance Parts 12 years ago. Any shop that sells ES can get you the upper and lower A-arm bushings. This should be the front control arm kit:
http://www.energysuspensionparts.com...?prod=3%2E3164
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
thenewkid
Apr 12, 2015 07:42 PM
sseeya
Apr 9, 2015 06:38 AM
thenewkid
Nov 27, 2014 09:41 AM
