Subframe installation question
Old Jan 31, 2003 | 05:24 PM
02MidnightblueZ28's Avatar
Question Subframe installation question
When installing subframe connectors, can you lift your car completely off the ground and install them or do you have to jack up with part of the car resting on the ground? Also, exactly where do they weld on to the frame?
Old Jan 31, 2003 | 05:31 PM
stik6shift98's Avatar
either or
Old Jan 31, 2003 | 05:42 PM
Bawls's Avatar
Make sure to have them welded in while the car's suspension is loaded. (drive on lift)
The SFCs connect your front frame to your back frame. They usually weld to your rear frame where your LCA's bolt into and the front of the car, you'll see it. Its right behind the plastic jacking point.
Old Jan 31, 2003 | 06:10 PM
hey bawls havnt seen u post in a while
welcome back
Old Jan 31, 2003 | 11:53 PM
jd13's Avatar
I've never heard that before. Could you elaborate on that please? I didn't have mine installed like that. I definatly feel the difference and after a few weeks my welds look fine and I've noticed no problems.
Old Feb 1, 2003 | 11:14 AM
Black91Z28's Avatar
Thats what i thought, i didnt think u had to load the suspension? If u do, can u elaborate as to why?
thanks
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
slothgrant
Aug 22, 2002 03:01 PM
Chrisdude
Jul 24, 2002 02:25 PM
