clutch reservoir
Old Apr 12, 2010 | 10:00 PM
jnm2003's Avatar
clutch reservoir
What types of reservoirs can i use to separate my clutch and brake fluids? I know about the GTOs but its on national backorder! What other year model or types of vehicles can i get one off of? I think i have seen a 1992 civic has the right reservoir?
If anyone can help to get me a list of possible reservoirs that will work? Im really in need of separating the two because of my stupid clutch pedal problems!
Old Apr 13, 2010 | 06:25 AM
JasonD's Avatar
Admin Emeritus
Um...what kind of vehicle?
Old Apr 14, 2010 | 02:39 AM
jnm2003's Avatar
2010 camaro LS3
Thanks!!
Old Apr 14, 2010 | 08:31 PM
JasonD's Avatar
Admin Emeritus
And what exactly are you trying to accomplish again? I am trying to understand the problem you need to solve but I am missing something.
Old Apr 15, 2010 | 02:06 AM
jnm2003's Avatar
The problem with havin the same reservoir for brakes and clutch fluid that allows more heat to get to the clutch fluid and that it costs more when doin a clutch fluid flush bc it's alot of fluid. I'm having problems with the clutch sticking to the floor after a few hard launches! I switched to high temp dot 4 brake fluid and it helped alot but still trys to stick and I race my car a descent amount! It may not be the only reason that the peddle sticks but at least will help hopefully. From what I hear we got the same slave cylinder problems like gm has had in the past! And other new camario owners that are racing with the stock clutch in it still for now are havin the same problem and put a higher temp fluid with a seperate resevoir, heat shielded the lines and some don't have the problem anymore and some are just doin it for a temp fix. Normally I should be able to get a full night at the strip of racing but after 3 or 4 passes the clutch starts trying to stick towards the top or just stays close to the floor if I race enough. Until gm puts in production a better slave I'm gonna try this!
Thanks for replying bc not many if any have on other forums. What is the requirements or types that will work for my clutch? Does it have to have specific diaphragms in the resevoir or specific sizes if seperated? And from what vehicles can I get one from bc the gtos are the ones everyones tryin to get but are on national backorder!
Old May 6, 2010 | 04:38 PM
TW95Z's Avatar
I haven't seen one of these so I can't say for certain, but I would think you could just get a clutch reservor for a 4th gen, find a spot to mount it on the firewall and run a hose from the clutch master to it. Plug the clutch line from the original reservor and continue to use it for the brakes.
Old May 6, 2010 | 09:52 PM
67 LS-1 & T-56's Avatar
I'm pretty sure this is what alot of guys are doing. The dual resevour is a pain. I had to have my whole master cylinder replaced within the 1st month because they couldn't get the cap to seal properly. Also, people are concerned that all of the clutch dust could be getting mixed in with the brake fuild and screwing up the ABS system.
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
