anyone running march power and crank series pulleys with a p1sc or d1.
is it posible to run aftermarket pulleys when you instal a s/c since you have to put spacers behind the factory crank pulley. i was just curious because im really thinkinking about going with a p1sc pullied down to 6psi. thanks
You would have to have some kind of spacer to go on the supercharger to move the belt out, and I don't know that you would have that much room. Much easier just to take the underdrive pulleys off and go with stock. Besides that, the gains from the SC will be way beyond what little bit you give up with the underdrive pulleys.
Re: anyone running march power and crank series pulleys with a p1sc or d1.
www.westol.com/lpavtis
Hope that Helps,
1LEThumper
Jul 14, 2003 12:45 PM
