Which knob is the fuel test port on a LS1? Also...
Old Jan 25, 2003 | 10:59 AM
ExMustangOwner's Avatar
Which **** is the fuel test port on a LS1? Also...
Which is the fuel test port on the LS1? Do you need that vavle stem core remover? And what part do you need to put in there? I got a used kit and will have to order the part.
Also, where did you mount your solenoids on your LS1s?
Thanks for the help
Old Jan 25, 2003 | 11:11 PM
XKnightRider's Avatar
Just follow the fuel lines, at the end of the rail there is a black cap, you are correct you have to remove the stem, then hook your fitting onto that. As for the noids you can put them where ever, mine are just underneath the windshield. Most people put the fuel noid mounted right on the fuel rail. I have some pics of it on my website.
Good luck and enjoy the fun!! N20 rocks!!
Old Jan 26, 2003 | 12:02 AM
Wow, thanks! Those pics help alot.
MadMav
Feb 6, 2015 11:02 PM
squarehead
Nov 21, 2014 08:02 PM
naaz90
Jul 27, 2002 08:22 AM
