Help way too much presser in my gas tank.
Old Dec 15, 2009 | 01:40 PM
crazypurgatory's Avatar
Question Help way too much presser in my gas tank.
I started smelling gas and when I got home I heard a hissing sound coming from the tank.
I would think that it was releasing the presser from the vent line very slowly.
So I took my gas cap off and I would say there was at least 15-25 PSI of presser there.
No check engine light on.
Something must not be working but why would my check engine light be off?
Thanks,
Old Dec 15, 2009 | 11:51 PM
There's no diagnostic to set a code for high fuel tank pressure. 25psi would probably cause the tank to deform and buckle outward.... not likely. The pressure in the tank is controlled by the pressure control valve that is part of the EVAP system.
Courtesy of Shoebox:
http://shbox.com/1/evap_system.jpg
Old Dec 16, 2009 | 12:29 AM
Question
OK so maybe it did not have that much presser but there was alot more that normal.
So I have a bad purge solenoid valve or a bad evaporate presser control valve?
Is there a way to check either valve?
I thought the purge solenoid valve had a code for it because it is a emissions device?
I hope you or somebody can help me out on this one.
I have not had a job in a long time and money is tight but I have to have my car running right.
Thanks,
Old Dec 16, 2009 | 09:26 AM
Its the pressure control valve that controls the pressure, not the purge solenoid. The "purge" pulls fesh air through the carbon canister. Has nothing to do with the tank. The pressure control valve is located between the tank and the canister. It is controlling pressure in the tank, not the canister.
Old Jul 17, 2010 | 08:01 PM
94Z28LS1toLT1's Avatar
thank u injuneer
hey injuneer i was reading threads about gas smell i had the same issue that this member had mine was hissing i heard it from the tank and it was my fuel tank vent valve thank u for all ur hard work for this website
Old Jul 18, 2010 | 01:18 PM
Question
Is there a way of checking the "vent valve"?
Thanks.
Old Aug 10, 2012 | 09:57 PM
Re: Help way too much presser in my gas tank.
Did u ever fix ur fuel odor issue
Old Sep 8, 2012 | 11:59 AM
Yes I did sorry for the late reply the system is not sending me my e-mail notifications.
The guy that owned the car before me put an amp in the trunk and put tow screws through the top of the gas tank and last time it was down I used some epoxy putty on the holes and it fell off so it was coming out of the holes in the top of the tank.
94Maroz28
Oct 27, 2015 04:38 PM
WobblySausage
Oct 7, 2015 10:09 AM
68camaroboltz
Oct 5, 2015 01:46 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
