What is the cause of the this sparking? help
Old Nov 11, 2009 | 09:51 PM
dalynchmob's Avatar
Ok so my car has been hesitating a bit and i starteed it with the garage lights off and saw the coil sparking on the coil wire. Replaced the coil wire with a msd 8.5mm and replaced my opti harness as well, it was cracked. Started the car and i can hear a audible clicking and see a spark jumping from the coil wire and feel the car missing. Would this be caused by a faulty coil or a failing opti? It has a stock coil on it and i don't see any arching coming from any of the plug wires. It's really driving me crazy. I need a solution.
Old Nov 12, 2009 | 03:47 AM
MikeGyver's Avatar
There's gotta be a big break in a wire or something if the spark is jumping to ground at the coil (path of least resistance).
Old Nov 12, 2009 | 10:13 AM
dalynchmob's Avatar
I'll replace the coil and wires today.
Old Nov 12, 2009 | 06:03 PM
dalynchmob's Avatar
OK i replaced the coil and i still hear and feel the sparking but don't see it anywhere. Guess it's on to the wires.
Old Nov 16, 2009 | 06:27 PM
Adam96Z's Avatar
My opti was making sounds like that the day before it crapped out. I believe the cap was at fault on mine as the optical sensor and sector wheel looked perfect, but just replaced the entire thing as it is a pain to have to do again.
Old Nov 16, 2009 | 06:42 PM
The Untouchable's Avatar
?somtimes the coil towers leak , and the only thing you can do is replace the coil, did you use dielectric grease on the coil boot?
on another note that clicking you hear with out any visible spark is usally on of two things carbon tracked distributor cap thats leaking elec or the sound of the rotor just before it comes apart or comes loose
Old Nov 16, 2009 | 06:45 PM
dalynchmob's Avatar
Replaced coil with msd, still doing it.
Old Nov 16, 2009 | 08:08 PM
get some dielectric grease and put it in the boot of the coil wire , and see if it helps, you should have no elec leakage at all.
Old Nov 16, 2009 | 11:48 PM
dalynchmob's Avatar
Gonna do the wires tomorrow since i already have them.
Old Nov 24, 2009 | 07:49 PM
dalynchmob's Avatar
Well i did the wires and took it for a test drive. I can still hear the clicking/sparking with the hood closed. It sounds like it's coming from the opti/coil area. It ran ok but wanted to almost die at every stop sign. RPMs would drop down to like 550-600 and then pop back up. It doesn't do it in the driveway during revs. I'm at my wits end with this prob. Everthing is new but the opti. No codes. I might actually have to break down and take it to a mechanic, I didn't think i wouldn't find the answer here.
Old Nov 24, 2009 | 07:52 PM
did u check the rotor in the opti to see if its loose
Old Nov 24, 2009 | 08:04 PM
dalynchmob's Avatar
How do i get into that sucker. I looks like i have to pull a lot of crap off. I believe the dampner hasto come off right?
Old Nov 24, 2009 | 08:20 PM
rclearyiii's Avatar
Yes..the balancer and water-pump have to both come off.
Old Nov 24, 2009 | 08:52 PM
dalynchmob's Avatar
The water pump too just to do the rotor F me!!!
Old Nov 24, 2009 | 09:13 PM
rclearyiii's Avatar
Yes..waterpump also...welcome to the LT1 DIY club.
